Ha yep. I left them on (clearly) when i painted my tail lights. I was not going to let myself get overspray on a then 4-5 month old car. So i drank a redbull one night, tape her up, and proceeded to sand, paint, wet-sand all the following day. Good times
lmao it would have been way easier to just remove the tails. gj nonetheless.
Not sure how that paint you bought works... but i used VHT Niteshades to do mine. Yours apparently is easily removable with gasoline? Just for a short period after your paint them or is it forever easy to remove? Just curious, because if it is permanent, you should sand your tail lights first prior to painting (fine grit, of course). And overly spraying leads to runs that will need to be sanded out. Overall though, good attempt and good luck finishing up the job!
ps: this is how you mask an entire car to avoid overspray!
Sorry i dont have any better shots uploaded to photobucket, so here's the same few i always end up posting. (I also dont know how to re-size ... sorry!)
