Fix-A Flat ????
I put new tires on my 250 about 4 months ago. Since then, the left front has been losing pressure at about 2 lbs. per week. The others are all fine. I know there's a slow leak somewhere but I've tried everything to find it and I can't. Wheel has been soaped, immersed in water bath, remounted, valve stem replaced and no joy! I've been thinking of putting some fix-a flat in the tire as a last resort but I'm concerned about its affect on the TPMS sensor in the tire. Any thoughts or has anyone tried this???
I wouldn't recommend using fix-a-flat for this. It will ruin the tire and should only be used in an emergency. And even in an emergency, people that do use this get this on the inside of their rims and it is usually a pain to remove. My recommendation...call a tire shop and verify that this information is correct. Hope this helps.
combfilter
05-26-07 12:58 AM
OAKPLANK
ES - 5th Gen (2007-2012)
10-23-06 02:58 PM
