How to remove plastic covers by little coin tray?
Hello, I have something rattling behind the little coin tray thing by the steering wheel. How do I remove those little plastic covers beside it? I'm assuming I can pry it out from the top or bottom of the cover with a flat head screwdriver but I don't want to mark it up. Any ideas?
Thanks!
Thanks!
Remove the flat side panel that sits against the door and pull the entire side that holds the switches toward the driver's seat. It will release and you can then pop the switches/blanks out from behind. Good luck!
Javier
Javier
DerekGordo
02-25-17 08:45 AM
