Fog light change on 2007 is250
anyone got any tips on how to access and change the fog light bulb on the driver's side? i read that there is an access panel that you can get to when the wheel is turned all the way to the right, but when i did that i couldnt see it. do i need to peel back the wheel well liner and remove the clamps first?
Actually, on the driver's side, there's a tiny cover you can remove to access the fog light. The hole is about as big as your fist. You won't actually see it inside the wheel well, but it's on the splash guard (or whatever you want to call it) AHEAD of the wheel facing downwards. I think it's held on with one clip. Unfortunately, there isn't one on the passenger side.
Actually, on the driver's side, there's a tiny cover you can remove to access the fog light. The hole is about as big as your fist. You won't actually see it inside the wheel well, but it's on the splash guard (or whatever you want to call it) AHEAD of the wheel facing downwards. I think it's held on with one clip. Unfortunately, there isn't one on the passenger side. ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
