Do you have any nominations for updates to the 2IS FAQ and DIY Thread?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
If you haven't read the 2IS FAQ and DIY thread please click here.
We are again taking nominations for links for threads that are not already listed that you have found most helpful, or you see being asked over and over again. Also for exceptional DIY (do it yourself) threads you have posted or read on the forum.
If you recall & have multiple links for answers the same question, please post them and I'll merge the threads and use the new link for the FAQ.
You must post a URL in order to nominate a thread for the FAQ please (not just a topic). Multiple URLs on the same topic are OK as well as we'll consider merging them into a 'master thread'.
This one comes up all the time: TPMS compatibility (and programming)
Answer is here, although hidden in other places too: https://www.clublexus.com/forums/is-...atibility.html
Here's a few.
Steering Wheel Damper
https://www.clublexus.com/forums/is-...ng-damper.html
Cracking Noise from Center Vent
https://www.clublexus.com/forums/is-...dual-vent.html
Carbon Fiber trim wraps
https://www.clublexus.com/forums/is-...s-of-pics.html
https://www.clublexus.com/forums/is-...m-removal.html
Door light LED strip
https://www.clublexus.com/forums/is-...strip-diy.html
Headlight height adjustment (easy way w/ AFS)
https://www.clublexus.com/forums/is-...djustment.html
LS460 door locks and led cups
https://www.clublexus.com/forums/is-...-cup-leds.html
Change out stock HIDS
https://www.clublexus.com/forums/is-...hid-bulbs.html
Remove grille
https://www.clublexus.com/forums/is-...-56k-nooo.html
Remove grille
is there any way to make the wording for the FAQ link bigger or different from the other sticky(make it stick out more)? cause newbies always skip over the FAQ and make threads without reading the FAQ.
as for suggestions
differences between 06-08 and 09+
https://www.clublexus.com/forums/is-...nd-09-2is.html
what light bulbs do i need for....
http://www.sylvania.com/ConsumerProd...lacementGuide/
as for suggestions
Forum Administrator
Thanks for the nominations and links folks, keep 'em coming.
yess. mine made it
we're getting some reallly good diy's lately. anyone know of a diy to make the footwell lighting brighter or keep it from fading out when you shift from park to R, N, D, or S? I want it to stay on bright when driving
Hey DaveGS4, could you please edit this thread to mention that you not only need to order the damper, but two (2) screws (part #90159-50199) as well? It is mentioned, but not the exact number you need.
Could we merge these threads on painting calipers?
https://www.clublexus.com/forums/is-...-for-help.html
https://www.clublexus.com/forums/is-...-calipers.html
https://www.clublexus.com/forums/is-...-question.html
https://www.clublexus.com/forums/is-...-on-is350.html
https://www.clublexus.com/forums/is-...us-decals.html
Here's one of a polished caliper
https://www.clublexus.com/forums/sus...-calipers.html
https://www.clublexus.com/forums/is-...ification.html
GFX Kit Finally Installed
GFX Front Spoiler Install
IS-F Rear Spoiler Without Drilling holes
Removing the grill
Removing the grill (2)
Painting the grill
Painted Emblems
Installing Fabulous Front Lip (Replica)
Carbon Fiber Wrapping
Carbon Fiber Wrapping (2)
F-Sport Sway Bar
Non-Nav to Nav
Replacing Side Mirror Puddle Lights
Removing Boot lid liner
Red-Outs
IS-F Rear End Conversion
Taken from links of bodykits, I don't know if those are all added in the FAQ. Will delete them once they are in the FAQ.
Removing the grill
Painting the grill
Painted Emblems
F-Sport Sway Bar
Non-Nav to Nav
Red-Outs
Forum Administrator
Great additions guys, keep 'em coming and we'll update all at once.
