Roof Spoiler (Ebay)
Old 05-13-10, 07:16 PM
  #61
file82
file82's Avatar
Originally Posted by julzcsar
After about 4 weeks of install, apparently water has seeped in because on my left side the adhesive is weakening. Solutions to get the spoiler to stick back on?
did you use 3M tape?
Old 05-13-10, 10:27 PM
  #62
pchan0
pchan0's Avatar
Which ebay seller did you guys buy it off? Any one brought a 077 paint code one? Does the starfire pearl matches your car?
Old 05-13-10, 10:36 PM
  #63
gbs350F
gbs350F's Avatar
i bought that exact thing for my car, it fits perfectly, and the color match is 100%, its good if ur not looking to spend a ton and it looks great
Old 05-14-10, 07:02 PM
  #64
julzcsar
julzcsar's Avatar
Aha yups just did. Simple fix. 3M FTW
Old 05-15-10, 12:53 AM
  #65
file82
file82's Avatar
my spoiler didnt line up very well but the 3M tape are too strong that i am not able to take it off... maybe i need to wait for a few months hopefully i can remove it on that time.
Old 05-15-10, 10:54 AM
  #66
MINI2na
MINI2na's Avatar
I just received my OEM.THING trunk and roof lips. While test fitting, I noticed that it looked like water will collect in the center of the trunk lid, behind the trunk lip. The 3M tape on the lip will create a "bowl". Do I want to cut the tape in the center to let this drain under the lip? Will this create problems with adhesion. Is this a problem for those that have them installed?
Old 05-15-10, 02:13 PM
  #67
GiantsFan
GiantsFan's Avatar
This seems like a good idea
Old 05-15-10, 03:33 PM
  #68
MINI2na
MINI2na's Avatar
I don't think a month is going to change things much. That tape is made to stick!
The 3M tape they use is much like the tape/adhesive used to put the IS350 and LEXUS badges on the trunk lid. The way you get badges off is to run a piece of dental floss under the letter/numbers and lightly "saw" off the badge through the tape.. (Then clean up the rest with GooGone or WD-40.) Maybe the same method would work with the spoiler.
You don't have a flat surface to work against and you would have to pull the floss over the existing lip of the trunk, so not sure if this would work.
Just a thought.
LEXAUDI
07-18-14 04:07 PM
Languistic
01-27-12 12:23 PM
odj1989
07-18-09 08:21 PM
w1ck3d64
04-30-09 11:37 PM
Big_GS300
07-11-07 12:17 PM
Quick Reply: Roof Spoiler (Ebay)
