finally coming together for Soleeasii!!!
#46
Slight vibration.. but I believe thats normal from what I've been reading on the fourms. As far as the overlays go... as long as you get it from a reputable store you should be fine. They all get the dimensions from the same place so fitament should be the same. Mine fit perfect, I believe mine is sherwood. I've also used woodview in the past on previous cars.
#49
Looking great![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I'd suggest considering the following changes:
- debadging, less is more
- repaint the LX grill in glossy black. Will look better with and without the LX detachable emblem
- add spacers to flush the wheels + fender rolling
- I find the Vertex rear lip a bit too odd (belongs to drift Silvia's not 2Gen IS IMHO). I'd swap them for perhaps the optional OEM rear lip (check Pocky's car) or even canceling the lip all together (my setup), they'll all flow with your side skirt and you'll get to keep your exhaust as is.
- repaint the VS-XX with a bolder color, Dangy's set comes to mind... perhaps candy gold or candy yellow
