cleaning engine bay
Old 04-21-10, 11:21 AM
hybridanim
hybridanim's Avatar
Default cleaning engine bay
Anyone tried cleaning their engine bay on their ISX50? If so, did you rinse it down with water after spraying engine degreaser on it, or did you wiped it down with a rag?
Old 04-21-10, 01:01 PM
Jetfire
Royale with cheese
Jetfire's Avatar
cover your alternator. ecu also if you're worried.
then rinse down a cold engine. spray some degreaser(p21s).
scrub with a good brush(like the ez detail brush).
rinse everything clean.
afterward either dry with a towel or dry with a leafblower.
drive around for a bit to dry everything off.
when everything is cool again, apply some dressing(303 aerospace).
Old 04-21-10, 02:00 PM
dappy
dappy's Avatar
Originally Posted by Jetfire
  • rinse
  • scrub
  • clean
  • dry with a towel
  • apply some dressing
Sounds like you're describing how to make a salad.
Old 04-21-10, 03:17 PM
Hoovey689
Hoovey689's Avatar
What do you use to cover the alternator Jetfire?
Old 04-21-10, 03:34 PM
hybridanim
hybridanim's Avatar
thanks JetFire!
Old 04-21-10, 06:04 PM
ecr527
ecr527's Avatar
You could use pretty much anything that the water won't get thru. I used to wash the engine on my old car with a grocery store plastic back.
Old 04-21-10, 07:10 PM
350police
350police's Avatar
My dad manages a self serve carwash. I have always cleaned my engine bay at the car wash.
My process is as follows:
1) Use rinse without applying the trigger (try to stay away from belts, electrical parts, etc.)
2) Apply tire cleaner (degreaser) again using no real pressure. Just let if flow out of the wand with out squeezing the trigger. I try not to stay on one spot, I never stop moving the wand.
3) I use the foaming brush on the large areas (hood, atop the grill area, etc.)
4) Spot free rinse (without applying the trigger) just let it flow and spray off the foam, soap etc..... again, moving the wand constantly
I have been doing this to every car I have owned (15 so far). I have never had a problem.
Just my experience
Old 04-21-10, 10:55 PM
iRock
iRock's Avatar
This processes sound good but I wouldn't use 303 protectant on anything. I've seen it do some bad stuff to things that it was applied to
Old 04-21-10, 10:59 PM
uz07lex
uz07lex's Avatar
Very helpful info and thread^^^. The girl will be getting a cleaning ASAP.
Old 04-22-10, 02:16 AM
Jetfire
Royale with cheese
Jetfire's Avatar
for the guys who asked, just use a plastic bag that's waterproof. modern cars you don't really need to cover anything, but i guess it's better to err on the side of safety.
may i ask where you saw this?
i've never seen any mentions of problems with 303. it's water based and doesn't have any solvents or petroleum products. it's usually highly regarded by detailers. i've used the stuff exclusively on anything that's not fabric or painted or glass on my car for close to a year now. on all the leather, dash, consoles, rubber trim, panels, etc.
what most people recommend against are dressings that are solvent based which over time will actually degrade your plastics and rubbers.
jdt
Automotive Care & Detailing
03-19-18 12:12 PM
Zinda
04-27-14 08:32 AM
soulsoarer
05-29-10 08:54 PM
airahcaz
Maintenance
03-11-10 11:27 PM
Angelo
02-05-10 09:58 AM
Quick Reply: cleaning engine bay
