IS250 Spark Plug DIY (half arsed) Basic necessity
Old 02-17-15, 07:36 PM
  #91
kopatropa
kopatropa's Avatar
Default Anyone know how to change spark plugs for 220D, "08??
Originally Posted by mIStaSC
So I left the Camera at home and I didn't get to do the DIY for you guys. I'm just trying to break it down to show you how easy it is.
I guess this would be a more advanced DIY since I'm not really showing you what I did. but it's basic common sense right in front of your eyes.
I bought the newly released NGK spark plugs to replace the OEM factory Denso spark plugs.
Tools:
10mm Socket-----RED
12mm Socket-----BLUE
12mm Wrench-----BLUE
5mm Allen Key-----GREEN
Intake Mani. Gaskets (3 Pairs)-----YELLOW
Extension
Spark Plug Socket or 16mm Socket
I've marked the pictures with certain colors as to what tool you will use.
Pic 1
Pic 2
Pic 3 - All you have to do is remove the Intake for the left side spark plugs.
Pic 4
Pic 5
after you remove that there should be connectors attached to the spark plug tubes. remove those. each tube has a 10mm bolt holding it down. remove that. then use your extension and spark plug socket to remove your spark plugs.
hope this helps!
sorry in pic 5 it says look at pic 4 for reference but it's actually pic number 1. pic 4 was the file name :X
Heres the Link to the NGK spark plugs thread.
https://www.clublexus.com/forums/is-...ailable-3.html
this took me about an hour and a half cause I didn't really know what to do at all. and that 12mm bolt behind the manifold is a BEEEECH
I have about 67k miles on my car. My OEM stock Denso plugs were still pretty good. so those who debate on changing them at 60k or 100k.. they will last till a 100k np IMO. I just like to change stuff out early to make the car last just like how I change my oil every 3k with synthetic when it's not necessary and can last till 5k. lol
Old 11-22-15, 05:38 AM
  #92
LC250
LC250's Avatar
Smile Wish I Saw This Earlier
Originally Posted by is250916
Tip:
If you stripped any of the Allen bolts, hammer a 3/8 socket on to it and wrench it off.
***Go to home depot and buy M6-1.0x30mm bolts to replace the stock allen bolts.
^This will help you out very much in replacing the spark plugs.
After an hour of frustration (and multiple cussing sprees directed at an inanimate object) I stumbled upon this post of yours. Can't thank you enough. I had tried everything to get this bolt out (the recessed one in the middle of the intake) and as soon as I hammered that 3/8 socket over it came right out. Thanks again.
Old 12-13-15, 03:31 PM
  #93
Bkhectic
Bkhectic's Avatar
Does anyone have the complete 50k maintenance list?? 2012 IS250 AWD
Old 12-13-15, 05:07 PM
  #94
EDU
EDU's Avatar
will keep this in mind also for next summer
Old 12-14-15, 09:24 AM
  #95
Bkhectic
Bkhectic's Avatar
Correction sorry. I meant the complete 60,000 mile maintance list.
Old 02-15-16, 08:49 AM
  #96
brooke2249
brooke2249's Avatar
Smart automotive (in houston, tx) quoted me $260.
I have to supply the spark plugs and intake manifold
that is the best quote ive received!
Old 03-18-16, 11:18 AM
  #97
usna2011
usna2011's Avatar
Coming up on 160K miles, Replaced the first set at 60K, since they still looked good I waited for 100K this time. From my experience working on older cars, one would usually replace the spark plug wires too when replacing spark plugs. I don't see needing to replace the spark plug harness that my IS250 has, but has anyone had any issues where the harness needed to be replace or are they just that well made that they will last the life of the car? Glad to see this thread is still here.
Old 02-25-17, 11:07 AM
  #98
dnwin
dnwin's Avatar
On the other write up it says "I will suggest to do it one plug at a time. Also, remember the order of wiring connectors. This is very important." What does this mean??>?
Old 02-25-17, 01:21 PM
  #99
dnwin
dnwin's Avatar
The back 12M socket that is a pain to remove! how did you guys manage to remove it? swivel ratchet? 12mm wrench? my hands barely fit back there!
Old 04-11-17, 12:06 AM
  #100
firelikeiy
firelikeiy's Avatar
Anyone have a list of part numbers for all gaskets that should be changed out during this service?
Old 07-30-17, 02:29 AM
  #101
ldc
ldc's Avatar
I'm going to embark on the DIY in the next 3-4 weeks. I have the parts and tools all set. I have done a DIY on a Toyota Camry the other day and i must admit it was easy. Doing it on a 250 and reading that you HAVE TO remove the manifold i'm abit concerned. But it got to be done!
I notice when doing the Camry the oem Denso plugs unscrew with abit of resistance (makes a screeching noise with every turn). It isn't that bad but when the plugs comes out it's all brown (not rust but brown). The car's done just under 63,000 miles. Would the brown on the thread be due to no anti-seize apply from factory? If so i would put anti-seize on when i do the 250 (but only a slight amount)
Btw, the plug socket i have is magnetic and clings onto the plug so there is no fear of drop it on the way up (or down).
Old 07-31-17, 07:56 PM
  #102
MikeFig82
MikeFig82's Avatar
Get a nut driver big enough with a hole that the Allen wrench can fit in. Use this a a leverage tool. Also make sure the Allen wrench sits in the hex bolts good. Sometimes there is dirt that accumulates inside. So if you don't seat it correctly it could cause the bolt to strip. The fuel line one is a little tricky it took my awhile to get it off, and the one bolt at the back of the manifold.
Old 07-31-17, 11:58 PM
  #103
ldc
ldc's Avatar
Picture of this but driver please. I thought I could use a normal 5mm Allen key that comes with them furniture install kits.
Would this do the allen bolts? I'm worried its not strong enough.
Or this one i think it's 1/2" drive.
Old 09-13-17, 12:25 PM
  #104
Copper_Hed
Copper_Hed's Avatar
Yes I need this as well! Some time ago there was a Dealer that sold everything as a kit through this forum, I'm not finding that info now.
Please Help! (also need other parts)
Old 09-16-17, 06:34 AM
  #105
Copper_Hed
Copper_Hed's Avatar
Hope this helps anyone else looking for info.
mylparts.com
CL5 for 10% discount.
My Lexus is a 2007 IS 250
THE.K.W.C
10-08-23 08:31 PM
Ants350
01-03-19 02:41 PM
Weapon F
IS F (2008-2014)
09-13-16 09:35 AM
food7373
Performance & Maintenance
12
07-27-16 11:51 AM
download
09-24-13 02:05 AM
Quick Reply: IS250 Spark Plug DIY (half arsed) Basic necessity
