Does sport mode do anything? IS350
Besides let me use the paddle shifters? Does it alter the timing like the power button? I remember someone mentioned Drive is actually better for acceleration than Sport mode. And in the FAQ someone states that normal not power is the best selection if your simply going to nail the throttle. So what is the formula for maximum acceleration?
Thanks
Thanks
Sport mode only allows you to control the gear you want the trans in. The power mode is what changes the shift pattern on the trans. Things like what rpm the trans up/down shift. In the power mode the trans shifts at a couple hundred rpm sooner.
Koz
Koz
I don't think extensive tests have been done on how power mode affects performance.
I think I've seen one test done. That just isn't sufficient for me.
The car feels like it accelerates faster from a roll in power mode versus normal mode. Obviously that doesn't mean that's actually the case, and it's more than likely a matter of perception due to faster shifts, but I'd like to see more, reproducible tests done to test the effects of power mode on performance.
It's hard to make conclusions from a sample size of n=1. I'd rather have multiple people doing multiple runs to see if the results are reproducible.
IIRC he was actually datalogging the car at the time.
https://www.clublexus.com/forums/3042656-post38.html
But that post is in a 7 page thread where others confirm the results, including those who did a fair # of 1/4 mile runs and always got better results in Normal mode than Power.
For those wanting to know what power mode DOES do, see here:
https://www.clublexus.com/forums/3305550-post10.html
As to SPORT mode- nope, useless. Gernby (in that same 7 page thread) tested putting the car in S mode/6 then repeating his tests and he got the same results as when the car was in D.
I found this out way back in the day when i drove my IS. I realized that the 2 times I had gone to the drag strip (and the DA was pretty much the same as previous sessions) I was running damn near .10 to .20 faster. Why?? Because i had forgot to push my ect/power button, and the results were better. I called caymandiver and he tried leaving it off the next few times he went to the strip. His results were the same. The IS is faster without using ect/pwr.
Like gernby's graph shows, it holds out on the shift points longer.
damn this was a long time ago, i just re read some of that thread.
https://www.clublexus.com/forums/3043100-post50.html
i think from stand still Normal is better
but Sport mode makes u "feel" faster cuz it holds the gears longer when u back off, so when go back on the throttle theres instant power
PWR makes the transmission more responsive (up shifting and holding gears longer to downshift). I don't see how that would physically make the car faster but it may make it feel faster. I usually crank PWR mode when I am in a hurry because the tranny hesitates less.
S to the K
08-02-10 11:33 AM
integlspwr
05-22-10 11:29 AM
