IS-F Wheels on IS350
I finally got a set of ISF wheels thanks to hblexus07. I wanted to share a couple things for future potential buyers worried about IS350 front caliper clearance. I tested it at a local shop and the MINIMUM clearance is 8mm, but if there is any play what so ever, it will hit the caliper. I decided to go with the 15mm Ichiba V2's, for the convenience of not having to redo the studs if i ever decide to install ISF calipers for clearance. I'll post pictures tomorrow.
Thanks to JoeZ, it was a problem easily avoided:
ISF wheels on ISx50
Cliff notes:
- 10mm minimum spacer to safely clear IS350 front calipers.
Update: iPhone Picures added below - 5/7/2010
Sorry about the crappy pictures, it was getting dark and iPhone sucks during this time of day. I'll hopefully get additional shots later. Possibly additional pictures with 10mm clearance. I'm still trying to decide if I want to go down to 10mm. At 15mm it's perfectly flush.
15mm V2 Spacer
![](http://i67.photobucket.com/albums/h282/jamesekki/photo.jpg)
IS350 Caliper Clearance
![](http://i67.photobucket.com/albums/h282/jamesekki/photo4.jpg)
IS350 Caliper Clearance Reference
![](http://i67.photobucket.com/albums/h282/jamesekki/photo2.jpg)
![](http://i67.photobucket.com/albums/h282/jamesekki/photo3.jpg)
Etc
![](http://i67.photobucket.com/albums/h282/jamesekki/photo5.jpg)
![](http://i67.photobucket.com/albums/h282/jamesekki/photo10.jpg)
![](http://i67.photobucket.com/albums/h282/jamesekki/photo11.jpg)
![](http://i67.photobucket.com/albums/h282/jamesekki/photo8.jpg)
![](http://i67.photobucket.com/albums/h282/jamesekki/photo9.jpg)
![](http://i67.photobucket.com/albums/h282/jamesekki/photo6.jpg)
ISF wheels on ISx50
Cliff notes:
15mm V2 Spacer
Etc
![](http://i67.photobucket.com/albums/h282/jamesekki/photo7.jpg)
8mm is fine, I've seen <6mm on some cars from the factory. There is no play in brake calipers, they're bolted tight. If they loosen up enough to give you a problem at 8mm of clearance, theyre gonna give you a problem anyway because they're going to eventually fall off completely. In essence, there can be 2mm of clearance. How much clearance do you think high compression interference motors have between pistons and valves? Its not inches, I promise
ISF wheels on ISx50
Cliff notes:
ISF wheels on ISx50
Cliff notes:
2IS OG
Javier
