Headlight alignment
I have a "gap" in mine, but there's still bleed over light in those areas, and I've had my lights dealer adjusted 3x in the last 6 months... and in my opinion, they're still not right.
The alignment on the IS will change after hitting a good sized pothole. I've adjusted mine many times. The headlights can be adjusted with a philips screwdriver (Look in the owner's manual). There are two adjustments for each side, one for height and one for the left/right movement. I find that I only have to adjust the height. There should not be any gap between them. I find a flat parking lot with a wall that I can draw a chalk line on (At night). I back up (Perfectly square) approx 30' from the wall. I measure the distance from the headlight center to the ground and the distance from center to center of the headlights. I then draw a horizontal chalk line at the same height of the center-to-ground measurement with a vertical line at each end of the line. The vertical lines should be perfectly inline with the center of the headlight to headlight center measurement at the ends of the horizontal line. Now you can adjust each headlight so that the center of the beam is vertically centered with the vertical chalk lines (At the ends of the chalk line) and the horizontal height of the beam is centered just below (1/2 to 1") the horizontal chalk line. This will insure the beam is focused at a slight downward angle. This all sounds complicated but it really isn't. I find that my way of adjusting the focus is better then the Stealer's.
Koz
Koz
The Stealer/OEM will adjust the driver’s side lower then the passenger’s (Too low). The beam cutoff line can be straight as long as the cut off line is just below the height of the headlight-to-ground measurement.
Koz
Koz
Koz
Koz
The way you describe is exactly as it should be per the instructions in the owners manual. They should both be exactly even with that line......contrary to what a lot of people say on this site about adjusting one side lower than the other. They don't realize that the reflector already makes one side slightly higher for them. It's designed into the lenses and reflectors.
mick_foley
27
03-16-10 08:40 PM
