Droid HTC Incredible w/ Verizon
Old 07-04-10, 11:05 AM
CombatTalo
CombatTalo's Avatar
I have the incredible as well. Did anyone get their phonebook to sync via. Bluetooth. 2006 is350 here.
Old 07-26-10, 05:42 PM
06LPBS
06LPBS's Avatar
i tried pairing my incredible today on a MY06, but it says that it's paired but it won't connect. Thoughts?
Old 07-26-10, 06:10 PM
SPNinjA
SPNinjA's Avatar
Hey guys,
I have a Motorola Droid. I'm pretty sure the incredible uses android as its OS. Go to the market and download Bluetooth File Transfer (BFT). After you've done so follow these instructions.
(PHONE)
1. Go to contacts
2. Hit the menu button and click on Import/export.
3. Export to SD card. (This will create a 0001.vcf file)
4. Open up BFT and it will turn on your BT and make your device discoverable.
-Go to your navigation, click telephone, follow by phonebook, transfer data, and then click on which ever group name or make one up on the previous screen with the register icon. After you pick one it should start the pairing process.
(BACK TO PHONE)
5. Click on remote files and find your cars BT and connect.
6. Go back to local files and find the 0001.vcf
7. Long press the file and a menu should pop up.
8. Click on send via bluetooth and Wa la! Your contacts from the phone should transfer into your navigation.
*If this does not work then, I don't know what else to do. Good luck!
Old 07-27-10, 07:30 PM
montgb
montgb's Avatar
Just ordered this phone today - looking forward to purging the Blackberry Storm from my memory.
Old 09-26-10, 09:38 AM
06LPBS
06LPBS's Avatar
Is anyone else getting the "paired but not connected" message with their incredible on a 2006 IS?
Old 09-26-10, 10:16 AM
MashinA
MashinA's Avatar
i wish i could stream audio through bluetooth on my nexus 1 :/
but the 3.5m jack works as well i guess!
Old 09-26-10, 08:14 PM
chikoo
chikoo's Avatar
Originally Posted by xuningshen
hmmm i don't get these threads, asking if their bluetooth on their phone works. isn't Bluetooth exactly that? bluetooth? reguardless of what kind of phone it is.
Not really. There is much to bluetooth than that.
For example, you cannot transfer your contacts from the iphone to the car using bluetooth. Other phones will allow that.
A windows mobile phone will not by default connect to the Lexus IS250 bluetooth unless you change a registry value.
Old 09-26-10, 08:31 PM
Tmoriarty
Tmoriarty's Avatar
you can check if lexus finds any phone compatible or not right here http://www.lexus.com/models/LS/acces...bluetooth.html
Old 04-16-11, 03:35 PM
Nikon
Nikon's Avatar
how do you get your phone to connect through the nav system? i can't get it to work.
fastdak25
05-07-14 08:25 AM
mshumack
RX - 3rd Gen (2010-2015)
13
11-29-13 08:39 AM
Ken300
03-12-11 06:19 PM
nwcn98
12-27-10 10:40 AM
OutCaster
02-15-08 05:50 PM
Quick Reply: Droid HTC Incredible w/ Verizon
