2.6" ARP Stud + Oem Lug Nuts?
I was wondering, will these work with OEM lug nuts with a 5-10mm spacer?
http://www.summitracing.com/parts/ARP-100-7715/
Has anyone tried it with a 5-10mm spacer?
I believe you can get away with using your stock studs for a 5mm spacer... not sure tho, make sure you get 6 full turns though on your lugz.
As far as a 10mm spacer, I would call Ichiba and buy there studs. Just tell them you need studs for a 10mm spacer and they will make sure its the right length.
