slight vibration during first warm up on the car.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
ok i did all the research about vibration but it seem to be during stop traffic and its on drive mode or park.my problem is this.I always warm up my car for the first start either morning or it does'nt matter just first start warm up and i could feel a slight vibration inside but once it warm up no vibration at all or all day.does anybody have the same problem.
miles 23000.
stock everything.
model. is rwd.
miles 23000.
stock everything.
model. is rwd.
If you're trying to describe something to other people, it helps immensely if you write coherent sentences.
my bad. What I'm trying say is that when you first start your car in the morning and wait until the temperature goes to normal. just by waiting in setting inside the car for that temperature goes to normal I felt a slight vibration.
well the reason,I warm up my car because.I want the oil to circulate to the head and lubricate the cams.I think is better to lubricate the top of the motor since all the oil stay on the crank overnight.is this correct or not.
The engine has proper oil pressure within 30 seconds of starting. If it didn't everyone who didn't warm up the car would be replacing their motors frequently, which they aren't.
(if you're especially paranoid you can use synthetic oil which has better cold-flow characteristics... but really, it's fine to drive the car by the time you put your seatbelt on... and it's better for it to do so. Idling is among the worst things you can do to the car).
Proper "warm up" is done by driving the vehicle.
All sitting there letting it warm does is waste fuel and contaminate your oil with condensation and blow-by from piston rings that seal poorly at idle.
thanks for the info.what about the vibration,I start my car today from sitting overnight and waited for just a minute or so and there is a slight vibration.again again its only first start up from sitting overnight.
