Can I use a GFX kit to hide this scratch?
Old 05-04-10, 07:41 AM
nysimonsez
nysimonsez's Avatar
Default Can I use a GFX kit to hide this scratch?
I scratched up the lower right side of the rear bumper and went to a couple of shops to get quotes on fixing it. One shop said he'll just fix the damage area and respray clear coat only to that area and it'll blend in to the original paint and not see a seam. He quoted to fix it for $300. The other shop suggests taking the whole bumper off and respray one clear coat to the entire bumper so it'll be sure to not have a seam. I'm still waiting for a quote but I suspect it'll be much more expensive.
Here's a thought I have, since the scratch is so low can I just buy a GFX rear (and probably front to match) to cover the scratches? With the part and install cost it may actually be cheaper than the fix. So my question is to those who have the GFX kit installed, how high does it go on the right side of the bumper? I want to be sure it'll be high enough to cover the scratches. Here's a couple of pictures of the scratches to give you an idea, sorry pic quality not great from my phone camera. thanks.
Attached Thumbnails Can I use a GFX kit to hide this scratch?-lex-1.jpg   Can I use a GFX kit to hide this scratch?-lex-2.jpg
Old 05-04-10, 08:28 AM
ExTrEmE99
ExTrEmE99's Avatar
If you buy the rear gfx kit, the bumper lip will hide that damage 100%. If you look at member's photos, the gfx kit sits a little under the reflectors.
Old 05-04-10, 09:06 AM
acefalcon2
acefalcon2's Avatar
yeah.... it will as extreme99 had said... i do think it's not a long term solution... unless the next buyer of the car does not look beyond the lips
Old 05-04-10, 09:22 AM
Frosty250
Frosty250's Avatar
The rear GFX lip should cover it no problem.
Old 05-04-10, 09:27 AM
bnizzle87
bnizzle87's Avatar
the kit would be a good solution. but i wouldnt get it until i know i couldnt get all the scratches off. your scratches dont appear to be deep, so a little elbow grease and some scratch doctor/ nu scratch should get most if not all of that out. i had something similar in my old ES, and it got it all off easily.
Old 05-04-10, 09:28 AM
LiCelsior
Retired
LiCelsior's Avatar
scratchx 2.0 will take 90% of it out.
Old 05-04-10, 09:30 AM
Secksee
Secksee's Avatar
most definately
Old 05-04-10, 11:27 AM
nysimonsez
nysimonsez's Avatar
Thanks for your replies. Unfortunately the scratches are deeper than they appear in the photo, I can feel it just running my fingers across them. Loose gravel from a sloped driveway did it (when I was backing up) so I think the gravel took off the paint on the bumper. Anyhow, I'm going to try buffing the scratches first (since I own a PC polisher) and see if I can get the scratches mostly off with just polish. If not then I'll be thinking about either a repaint or GFX (since it's now confirmed that's an option). I don't plan on removing the GFX if I do sell the car since I'll need to replace the bumper if I do as it'll be cut to install the GFX. I'm hoping the polish will get most if not all the scratches out.
Old 05-04-10, 11:32 AM
rule1223
rule1223's Avatar
good idea!!! it covers 100%
Old 05-04-10, 11:39 AM
blk250
blk250's Avatar
yep, rear GFX lip will help you solve this
Old 05-04-10, 02:11 PM
Rash
hmm
Rash's Avatar
Old 05-04-10, 04:53 PM
PaPaHoFF
PaPaHoFF's Avatar
Is this even through the paint?
It just looks like a scuff / paint transfer that can be removed with a compound and polish. Take it to a local detailer to see what can be done first..
Old 05-05-10, 06:00 AM
nysimonsez
nysimonsez's Avatar
I looks like it's through the paint but I could be wrong, and hope so. I'm going to try to polish it out this weekend. Hopefully it'll be mostly gone and the rest I can just touch up. But at least I know one option in the end is to get a GFX.
LaosXpress
03-30-10 08:35 AM
iceache925
04-22-09 10:07 AM
xlegend25x
09-08-08 10:11 PM
Lextasy89
05-11-08 10:02 AM
Quick Reply: Can I use a GFX kit to hide this scratch?
