Hi, I try putting 5mm spacer without studs at the rear of my IS350 with aftermarkets wheel, it seems that the OEM studs are kind of short, cuse I only get like 3.5 full turns from my lug nut, from what I have heard b4, don't I need atleast 5 and up full turns?
i mean 3.5 turns is a little tight (4+ turns is perfect) but you "should" be good.. i mean as long as you check every once in a while and make sure there tight.. and you should be good
get the correct size lug bolts. find out what the oem size is, then add 5mm to it. Dont go by turns. This is your wheel we're talking about. Dont want to risk it coming off when your doing 60mph down the highway.
