Another lowbeam /highbeam/fog thread
Okay I have searched and searched and searched. I got so much information I think I may have confused myself. Which need just bulbs and which need the kit with the ballast. I think it also depends if its stock HID or not. Mine is not stock HID, atleast i don't thinks so.
Please help I am losing it?
If you don't have stock HID, you need to get HID kit(ballast + bulb + wiring) for your lows if you want. If it's 07+ chances are it has stock HIDs. If you need HID though, you can get them from the vendors on the forum. Lows if not HID are H11. If they are HIDs, D4s.
High beam is 9005.
Fogs are 9006.
High beam is 9005.
Fogs are 9006.
Right now in your car it is just bulb. You will need ballast and wiring if you want to go HID.
http://hidextra.com/
You can get the kits from here, I dunno, wouldn't go HID for high beam though just burn the bulb quickly if you don't have DRL's disabled and would be hella dbag at night when you highbeam people. Also wouldn't really see the true output because it wouldn't be on long enough to warm up.
Okay Kurtz seems like you got the info i need so i just got confused. So only low beams need the balast and wiring. The highbeams and fogs i can just switch the bulbs then if i want?
Check the vendor forums. I think HIDExtra sells a decent kit for $60 or so.
Here are links to a couple of lighting threads I've made to give you some ideas:
Before: https://www.clublexus.com/forums/is-...ng-lights.html
After: https://www.clublexus.com/forums/is-...fogs-pics.html
But they are not, and have never been, a standard feature on the 2IS.
There's more than a few threads on here with people who don't have factory HIDs in 07+ cars and are annoyed because they thought they were standard.
The only thing that changed on 07+ cars was those had the OPTION to get them without the sport or lux package... in 06 they only came in those packages, 07+ you could get them either in those packages or as a stand-alone option.
To the OP- Yes you can just swap bulbs for fogs or high beams if you want to. They won't look like HIDs though so if your lows are HIDs they still won't match "perfectly"
One thing that I was confused with and I haven't seen mentioned anywhere is that the OEM HID/Bi-Xenon lows have some high-beam function.
For example I was warned that if I installed LED DRL's i would lose high beam function... I installed them and discovered that though it's not quite as good, there's still considerable high beam function given by the OEM Bi-xenons. don't know if this function is specific to bi-xenon or if HIDs would also give the same.
