Vibration when lifting off gas pedal
Old 05-16-10, 09:58 PM
prankster
prankster's Avatar
Default Vibration when lifting off gas pedal
Hi guys,
I just noticed that whenever I lift my foot off the gas pedal only above 80mph, I feel vibration throughout the body of the car (I feel it on the seat). There is no vibration on the pedal it self and steering wheel.
Do yall have any idea what is wrong?
Thanks!
Old 05-16-10, 10:10 PM
new.era.13
new.era.13's Avatar
maybe tires? rotors being uneven?
Old 05-17-10, 06:58 AM
prankster
prankster's Avatar
The car is fine when braking and cruising below 80mph. The vibration was only felt when I lifted my foot from the gas pedal above 80mph.
Could it be the drive-shaft?
Old 05-17-10, 07:16 AM
nmpeter
nmpeter's Avatar
I had this on my car when I drove with unbalanced tires and no hubrings (on Vossens). Once I mounted my wheels back on the vibration no longer existed. I'd go get the tires rebalanced.
Old 05-17-10, 08:05 AM
prankster
prankster's Avatar
Would you recommend me to get the hub-rings? I will rebalance the wheels as well.
Old 05-17-10, 09:06 AM
ToniS250
ToniS250's Avatar
Yup i had the same problem , I actually hit a curb and after that it started doing the vibration I took it to dealer and they fixed it in no time! They said it was the rim it self
Old 05-17-10, 10:43 AM
nmpeter
nmpeter's Avatar
If you have aftermarket rims then yes.
Old 05-17-10, 10:53 AM
prankster
prankster's Avatar
I have OEM wheels. I'm still not sure if the wheels are the problem. My car is fine above 80mph with foot on the gas pedal. Are yall have exactly the same problem (only when you lift your foot off the pedal)?
But I will rebalance them anyway.
Old 05-17-10, 10:59 AM
ToniS250
ToniS250's Avatar
Prankster I VE HAD THE SAME PROBLEM LOL. Trust me its the wheels not tranny or else.
Old 05-17-10, 11:07 AM
prankster
prankster's Avatar
Thanks for confirming that Toni! I just wanna make sure you got the same problem. I will get them rebalanced and buy hubrings.
Old 05-17-10, 12:11 PM
ToniS250
ToniS250's Avatar
you r welcome bro, let me know after u balance 'em thnx
Old 05-17-10, 02:20 PM
nmpeter
nmpeter's Avatar
If you're on your stock rims just rebalance them, hubrings wont even fit on lol.
Old 05-17-10, 02:25 PM
sway162
sway162's Avatar
I just had this problem last week. lol
It was that my front two tires needed to be re-balanced. Now it's solid.
Another issue is you have a bulge in your tire....but with this you should feel vibration and steering wheel shaking at certain speeds while your foot is on the gas pedal.
Old 05-17-10, 07:42 PM
albis350
albis350's Avatar
I am starting to feel a slight vibration on my steering wheel at certain speeds gotta re balance the front rims also I am hoping i not a bubble in a tire since i got the fk452s and they have a bad reputation on bubbling....
Old 10-22-21, 10:09 AM
Kmoore0010
2nd gear
Kmoore0010's Avatar
I know this thread is really old but did balancing your tires actually work for you? I have the same issue and did that and it didn't help...
Quick Reply: Vibration when lifting off gas pedal
