Damaged My Fender after Dropping on Coils
Old 10-27-10, 01:38 PM
  #46
MashinA
MashinA's Avatar
did u ever fix it? if so lets see it!
Old 10-27-10, 08:25 PM
  #47
rcJten
rcJten's Avatar
I never took a pic of my passenger fender damage cause it hurt me to much to think about it. But got the car back today from the body shop and it looks great!
Suffice to say, my car is now 10mm higher all the way around
Old 10-27-10, 08:56 PM
  #48
Mv350
Mv350's Avatar
haha i was dumped and my fenders, frame, exhaust, bumpers, and ears will never be the same after i sold it
Old 10-27-10, 09:10 PM
  #49
onilink
onilink's Avatar
Originally Posted by brociouz
I learned this the hard way. I always heard you're supposed to angle into driveways to avoid scraping, but I thought that meant angling the wheels, not the car itself. Oops.
It is a lot easier to angle your car by turning your wheels and then angling, the point being that the curb of the driveway (or speedbump or whatever you're trying to get onto/off of) hits your tires first and helps lift the car up so you don't scrape. You have to be going pretty slow to not angle your tires and just angle the car with the tires straight, it would also be an extreme angle and you would end up scraping the other side of the car badly. (But it is doable if you learn after time from driving a dropped car) That's why it's best to stiffen up the suspension and roll your fenders when dropping low so you can still turn and prevent effing up your fenders.
Old 10-27-10, 10:13 PM
  #50
BORIS350
BORIS350's Avatar
wow this really sucks.
makes me think twice if i should drop my car or not.
Old 11-18-10, 09:33 AM
  #51
UtoyZ
UtoyZ's Avatar
same thing happened to my car yesterday. this is the pic of the damage:
does anybody have an after-fix pic? thanks
Old 11-18-10, 09:46 AM
  #52
ohiois350
ohiois350's Avatar
wow what size and offset you run?
Old 11-18-10, 09:59 AM
  #53
UtoyZ
UtoyZ's Avatar
I run 19x9 +30 with Falken 235/35.
Old 11-18-10, 03:00 PM
  #54
ohmarvin
ohmarvin's Avatar
It really doesn't look too bad. And doesnt look like there any damage on liner. Some love taps and heat could do it.
Old 11-18-10, 03:12 PM
  #55
UtoyZ
UtoyZ's Avatar
got it fixed but now it's wavy and i'm not very happy about it (some paint chipped off too)but what can i do,it's the price of being too low
Old 11-18-10, 03:20 PM
  #56
brociouz
brociouz's Avatar
I don't think I have any after fix pics handy. When I first had this damage I took it to a PDR guy and he did a great job. I'd say he brought it back to 95%+ original. However, I did the same damn thing a second time after that fix, and when he tried to fix it a second time the paint chipped and it just doesn't look the same. If I find a fender in a junk yard I might snag it and fix it, otherwise I'll just deal with it. The only aftermarket fenders I'm aware of are Artisan Spirits, but too flashy for my taste.
Moral of the story: ROLL YOUR FENDERS PEOPLE, even if you think your offsets are conservative.
Old 11-18-10, 03:40 PM
  #57
Proper 350
Proper 350's Avatar
we're in the same boat.mine looks just like that but worse,wayyyy worse.im goin to get a dent wizard guy i know to fix it.only way to prevent it from happening again is to not be so low and to cut and roll
Old 11-18-10, 08:10 PM
  #58
VIS250P
VIS250P's Avatar
I remembered this happen in the past.. One time I went over the steep road and forgot to make a awkward angle instead of straight.. It was too late, I mess up driver side fender and it look similar as everyone in the pic of damage.. I used wooden bat underneat the driver fender and then roll it minimum work.. It doesnt look bad and nothing can make straight and smooth as stock.. IT happened.. Oh I forgot, now Im running 19x9 22 et front and there was no rubbing.. Im happy because I used roll fender tool and pull front fenders more out..
Old 03-31-11, 07:27 PM
  #59
SB350
SB350's Avatar
This just happened to me in the same spot on the same side. It looks almost identical to Brian's damage. I knew I was playing with fire and already had an appointment to get my fenders rolled in a couple days. Hopefully it will get fixed when the fenders are rolled. damn.
Bumped an old thread, Haha!
Old 03-31-11, 07:31 PM
  #60
lexusis305
lexusis305's Avatar
Smaller tires and roll the fender and your good to go
Quick Reply: Damaged My Fender after Dropping on Coils
