Headlight Amber light
It is 3 amber leds
Edit: jk i'm kidding about it being a 194 bulb. Are they leds that are part of the headlights fixed in so you can't change them?
Pocky's right - the amber piece doesn't use a 194 bulb, the parking light does. The amber piece uses an LED board - quite obvious when you open the headlight housings. It doesn't function as a turn signal marker either - like stonefan52 said, the LED comes on when your parking lights come on. Honestly, I like the amber piece on the side. I've had my headlights open a few times and had ample opportunity to paint it, but I like the way it looks - especially with the way my headlight housings are painted now.
Javier
Javier
hmm that amber light is only one bulb? whatcha guys talking about.. it does use a circuit board but it's only two bulbs. You would have to sodder the new LED on it if you wanted to change it out
