Manual Transmission oil change
Old 05-20-10, 06:53 PM
racerboi07
racerboi07's Avatar
Default Manual Transmission oil change
Has anyone on here changed their oil for the manual transmission box? If so, how do I get about doing it. Thanks
Old 05-21-10, 05:45 AM
quick123
quick123's Avatar
Ok, I have never done this myself on an IS, but I have done it plenty of times on my Saturn and other cars...so let see...
1st of all, ONLY USE API GL-5 fluid when you fill it, that comes straight from a Lexus TSB.
The way to drain and fill the fluid in a manual transmission is very similar to how you drain and fill a differential. There is 1 drain plug at the bottom of the housing, and 2 fill plugs, one on the side and one on top. I tried to include some diagrams of the transmission components so you can see where these plugs are, but I can't get the diagrams to upload properly, sorry....and remember to replace the gaskets as well.
To drain and fill, make sure the vehicle is level, and remove the bottom drain plug to drain all the fluid out. Once the fluid is all drained out, clean the drain plug and re-install it with a new gasket. Then remove both the fill plugs. You should pour the fluid into the top fill plug until it starts to spill out of the side plug. Once it stops spilling out the side, re-install both fill plugs with new gaskets, clean any residual fluid, and you are done.
Again, I have never done this on an IS, so there might be something I am missing, so everyone who has done this please chime in...
Hope that helps!
Old 05-21-10, 07:06 AM
B16da9
B16da9's Avatar
^^^ you got it correct. Just about all manual transmissions cars use this method.
Old 05-21-10, 09:12 AM
shui3000
shui3000's Avatar
you can't change it. use the search function. it's been talked about ad nauseum.
Old 05-21-10, 09:28 AM
quick123
quick123's Avatar
No...that is AUTOMATIC trans fluid, not MANUAL trans fluid....
Old 05-21-10, 11:10 AM
B16da9
B16da9's Avatar
Follow what you preach and read the thread before reply with "Search".
Old 05-21-10, 11:42 AM
racerboi07
racerboi07's Avatar
haha thanks guys for the help.. well shui3000 was no help.. ill let you know how it goes.. =)
Old 05-21-10, 01:49 PM
ULTiMaX99
ULTiMaX99's Avatar
do a diy with photos!
Old 05-21-10, 07:06 PM
mild_se7en
mild_se7en's Avatar
quick123 pretty much said it, except break loose the fill plugs before removing the drain plug. it really sucks when you find out your fill plugs are frozen after all the fluid is out. just a tip. and a diy with photos would be great.
Old 05-21-10, 07:43 PM
es808
es808's Avatar
I actually had to change the pressure plate and clutch disc on my IS250 since it was worn from the previous owner. In the process, I had to drain and fill the trans fluid. Draining was simple since the drain plug is the only plug at the bottom of the trans bell housing. Should be pretty easy to locate once you're under there.
Sorry I don't have any pictures to post at this time.
The filler plug is on the side of the transmission on the driver side (left side). If I remember correctly, it was 90 degrees from the drain plug in the horizontal position. The following pdf file shows the service level of the fluid. But be warned! The filler plug is in a tight space between trans housing and the body. You will need a pump (manual or otherwise) to be able to pump the fluid into the filler opening.
I got a hand pump from a local tool store and used it to pump the fluid into the transmission. Without this it would have been very difficult to get the fluid into the transmission.
Hope this helps.
Old 05-21-10, 10:25 PM
ahnjae
ahnjae's Avatar
Yeah this will be my next maintenance job I do since I got a bit over 60,000 miles on the IS. Will probably go with Redline Synthetic. Does anyone know how many quarts the bell housing requires?
Old 05-22-10, 12:01 AM
es808
es808's Avatar
The owner's manual states 1.9 quarts, API GL-4 or GL-5 with a viscosity of SAE75W-90.
Good luck with your tranny fluid change.
Old 05-22-10, 11:17 AM
Koz
Koz's Avatar
Can not get better then this!
http://www.amsoil.com/storefront/svg.aspx
Koz
Old 05-23-10, 07:23 PM
ahnjae
ahnjae's Avatar
Koz
Yeah Amsoil is good stuff....and i just might have to go with that cause Redline MT-90 is only comes in GL-4...Ive just always used Redline in all my other cars so im so used to it.....oh well
Old 05-24-10, 01:25 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
I tried MT-90 and seems it's a little too thick...I then switched to Mobile 1 75w90
Quick Reply: Manual Transmission oil change
