Old 12-16-14, 12:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
DIY: IS350 Spark Plug Service
Old 08-05-12, 02:34 PM
  #106
rsg
rsg's Avatar
I just ordered Denso FK20HBR11 plugs from Autoplicity.com because it was cheaper than Sewell. Will the gap size be different on these?
Old 01-09-13, 04:08 AM
  #107
Bkloudest
Bkloudest's Avatar
Any recommendation on spark plugs? I have IS350 with 60,223 miles and Im looking into changing out the plugs.
Please advise
Thanks
BK
Old 08-12-13, 11:36 PM
  #108
lopaka07
lopaka07's Avatar
followed this thread and did my 60k spark plug service. Thank you javyLSU. $75 for plugs and 1.5 hours of labor finished the job. Dealer quoted $320.
Old 09-10-13, 01:54 PM
  #109
imaina89
imaina89's Avatar
Saving this thread. Will need it next week. Thanks!
Old 09-16-13, 05:56 PM
  #110
mandyfig
Forum Moderator
mandyfig's Avatar
I have my plugs lined up. I need to look at that pia bolt everybody's cursing on...patience and research, it will lessen the pain. I can not wait to do the plugs on the 350.
I did my 1st oil change and it was a breeze (btw mine has no bottom plug, it is one piece and I used the old filter cap I had used for my 1995 Camry, fits perfect). Detailed the wheels, now that was a chore! Detailed means cleaning inside the rims, too. Plus touch up paint on the rims. Those are heavy rear wheels!
And lastly replace all missing clips on the engine bay, courtesy of lazy service techs, not putting the clips back on, hate that.
Back to the plugs...I use anti-seize and I will use a torque wrench on this one. Previous I use the NGK method of 1/3 to 2/3 turn to seat the crush washer portion of the plug. but I will now use the torque wrench, just lazy to adjust it to 18 ft-lbs, it is set permanent to 76 ft-lbs for the rim lug nuts, LOL!
Old 09-17-13, 07:41 PM
  #111
smokyis350
smokyis350's Avatar
Just did the spark plug maintenance. It took me 45min to change out the passenger side and 4hr to change out the driver side because there is like no room to work with.
All I gotta say is that the driver side most front spark plug is a real pain in the butt. I spent 3hrs to use a ratchet 10mm wrench but there was literally no room to swing it loose. I ended up using a 1/4in 10mm socket and forced it at a angle to loosen.
Old 09-18-13, 10:24 AM
  #112
mandyfig
Forum Moderator
mandyfig's Avatar
So does it make sense to actually loosen up the manifold to gain access? I am just going by memory, that’s what I understood from a member...
Old 09-18-13, 12:37 PM
  #113
smokyis350
smokyis350's Avatar
I don't remember anyone saying they took off the manifold. But if you remove the manifold, it would be 10x easier on the driver side.
Old 09-18-13, 12:58 PM
  #114
4TehNguyen
4TehNguyen's Avatar
I didnt take of the manifold but it took a while because I could only turn one of the plugs 1/16 of a turn at a time due to clearance. universal joints and varying lengths of extensions wouldve helped.
Old 09-18-13, 05:09 PM
  #115
laobo979
laobo979's Avatar
Dame 4hrs I did mine in 1 1/2 both side. Even did the 250 and it wasn't 2hr.
Old 09-18-13, 07:35 PM
  #116
smokyis350
smokyis350's Avatar
That include eating lunch also but yeah. I was stuck on this stupid bolt for hrs. Stupid engine manifold.
How did you remove this?
Attached Thumbnails DIY: IS350 Spark Plug Service-screen-shot-2013-09-18-at-7.29.20-pm.png
Old 09-18-13, 08:26 PM
  #117
4TehNguyen
4TehNguyen's Avatar
i used a close ended wrench, turning it 1/16th of a turn at a time, took a while lol
Old 09-18-13, 09:36 PM
  #118
laobo979
laobo979's Avatar
I used an Craftsman reversible ratcheting wrench google it. It work like a charm to losen that bolt then with your finger get it the rest of the way out.
Old 09-18-13, 10:25 PM
  #119
smokyis350
smokyis350's Avatar
I have the exact same thing. Craftsman 10mm ratcheting wrench. I tried using that first but it was torqued way too tight. I couldn't get the leverage or the room to swing it loose.
I really need to invest in these angled sockets..
Old 11-09-13, 06:44 PM
  #120
ISFjimmy
ISFjimmy's Avatar
I just finished changing the plugs on my 07 GS450h. Took me about 2 hours or so. Passenger side was super easy but, I almost gave up like twice on the driver's side. I used a gear/ratcheting 10mm wrench for the driver side bolt farthest from the firewall and eventually got it off. It took me a while because I felt the wire harness was too in the way so, I loosened as many bolts and wires as I could and eventually there was enough room. Thinking back on it, it actually wasn't too hard, I just felt like giving up because I thought there was no way the coils could come out. I could probably do it in about an hour if I had to redo it again.
Quick Reply: DIY: IS350 Spark Plug Service
