Brightest LED Parking Light - the Definitive Guide
Old 12-09-10, 01:17 PM
  #91
gdcheng
gdcheng's Avatar
Then how do you get your Fog's on at the same time as your DRL's? I put in some LED's for my DRL's and lost the Fog's when i turn on my high beams. The DRL's turn off when the low beams/fog's are on....
Old 12-09-10, 01:39 PM
  #92
brociouz
brociouz's Avatar
^ Those aren't my fogs. They are a custom LED strip controlled by remote control. Read this for more info: https://www.clublexus.com/forums/is-...ing-video.html
You can also do the standalone fog mod: https://www.clublexus.com/forums/is-...ication-8.html
Old 01-06-11, 06:32 AM
  #93
LexStylez
LexStylez's Avatar
hey brociouz do the LED parking lights flicker like the LED DRL?
Old 01-06-11, 06:41 AM
  #94
Gustavo250
Gustavo250's Avatar
No LED parking ligths do not flicker
Old 01-06-11, 08:11 AM
  #95
brociouz
brociouz's Avatar
First post updated to reflect changes in V-LEDS lineup.
^ This.
Your LED DRLs shouldn't flicker either assuming you properly installed a module and/or relay harness.
Old 01-06-11, 11:35 AM
  #96
DaRza
DaRza's Avatar
thanks for the great info. i wish more people had postings with such great details..
Old 01-07-11, 02:40 PM
  #97
brociouz
brociouz's Avatar
^ You're welcome.
Old 01-07-11, 02:49 PM
  #98
LexStylez
LexStylez's Avatar
Thanks Gustavo250 and brociouz. Now I know why brociouz is the go to guy when it comes to lighting Would the V-LEDS 5K WHITE 194 13 LED LIGHT BULBS (http://www.v-leds.com/Interior-LED/G...04828-1-2.html) for parking lights be a good match with non HID low's?
Old 01-07-11, 02:59 PM
  #99
brociouz
brociouz's Avatar
^ It would be a pretty good match, but http://www.v-leds.com/Exterior-LED/C...85865-1-2.html might be even better. It's a litter dimmer, so it'll blend better.
Old 01-07-11, 03:11 PM
  #100
LexStylez
LexStylez's Avatar
Okay I'm going with 5K SMT HIGH POWER LED. They're out of stock! I'm going to pre order. Thanks again brociouz.
Old 01-07-11, 04:53 PM
  #101
crazybuggy
crazybuggy's Avatar
sooo helpful... gna use this to buy new parking lights
Old 04-24-11, 12:04 AM
  #102
RasAlgethi
RasAlgethi's Avatar
Hmm, anybody got a shot of 5k compared to 6k? I don't want too much blue but its hard to tell unless the pics are side by side of the same fixture/housing.
Old 04-24-11, 09:52 AM
  #103
IS35O
IS35O's Avatar
Can you PM me a shopping list on everything I need to get all matching LEDs in my headlights and foglights, to compliment my garax 6k lows?
Old 04-24-11, 10:57 AM
  #104
armstronga
armstronga's Avatar
http://www.v-leds.com/Exterior-LED/D...69956-1-2.html
are these the new drl that dont require a relay harness or module? Just plug and play???
Old 04-27-11, 10:05 PM
  #105
brociouz
brociouz's Avatar
Look at your at the LED reading lights by your front dome light. Those are about 5000K. 6000K has a small hint of blue in it.
https://www.clublexus.com/forums/is-...de-w-pics.html
Yes, those are the new ones. They still require a module (to prevent flickering, a module is always needed) but it is plug and play and the actual module is small enough to fit behind the moisture shield. No drilling, no relay harness to the battery.
Quick Reply: Brightest LED Parking Light - the Definitive Guide
