MY IS scare the poopy out of ME
I was driving on the carpool lane from LA to OC today and suddenly a big BAMMM
I pulled over to check.
I got Sumer tires W225/40R18 Fr + 255/40R18 Rr that came with the car
HOW CAN I FIX IT SO IT WON'T HAPPEN AGAIN??
AND
Now I need new Front tires any advice will be appreciated.
AND
from my experience, he probably didn't run over anything. are you on any type of lowering system (springs or coils)? when I installed tein s-techs, the camber caused this to happen to my fronts. This is the same thing that happens to rear tires, just takes a lot longer for the rears usually. I had my stock front tires on for about 25,000 miles and i had a metal line going around the whole tire. stock camber is crucial so you don't run into this problem again, i just say get an alignment more often, that's all i do now.
Both Front tires are the same. I believe they are rubbing but with what??? I check the liner but NADA they seem OK
Is my IS too low? I dont think so my car is still Stock no Mod. on the suspension.
