Navigation System Help. GPS Does Not Show Correct Location
Car: 2006 Lexus IS350.
From one day to the next my GPS, does not show the correct location on the screen. The screen looks perfect and streets do to as well, but they are not in the vicinity of the actual location to where I am at. It is maybe off by 10-15 miles.
Everything else works fine, including the touch screen. Will post video of it tomorrow.
I want to take in to the dealership, but my car just finished getting out of manufacturer warranty.
I tried searching for resetting or restarting the navigation here on CL, but only found the method for GS models.
Anyone have any suggestions?
There was a Technical Service Bulletin for that. Maybe you can sweet talk them into doing it for you, even though you are out of warranty, given that it may be a costly repair, and should have been taken care of by now?
The bad news is you lose the software override that only the 06s had.
This happened to me a couple years back. Initially they told me that the satellites were probably out (yeah right), but when I mentioned the TSIB, they all of a sudden changed their tune and had me bring the car in. They replaced the navigation DVD. Haven't had a problem since.
Having the same issue on my 06 250. Location is off by 40-50 miles. Dealer just replaced the airbag harness and Navi was off since then. They also scratched my dashboard to hell and didn't even put it back together correctly. Anyways I have an appointment tomm and my car is under Lexus warranty until Oct 2017. I purchased Lexus care again 2 years ago. Its already paid for itself.
Gx460 gps problem
My 2014 GX460 lately has been encountering the same issue. I have found that disconnecting the negative cable for 30 seconds and then reconnecting it allows the GPS to reload. It is not a permanent fix as it may last for 5 hours of driving.
2007, correct, disc, do, generation, gps, is350, lexus, location, ls460, navigation, reset, satellites, show, system
