Another HID and Lighting qusetion.
Old 06-14-10, 08:52 PM
poorkidlol
poorkidlol's Avatar
Default Another HID and Lighting qusetion.
Hi everyone, I've tried searching but obvious my brain is too small to understand the differences. Installing HIDs in Canada are too expensive so I'm going to follow the DYI guide and save money. Anyways, not trying write an essay here, I want to install HIDs on my non HID Lexus.
I've heard good reviews about the Garax Low Beam 6000k bulbs
I now need a kit (Ballast + Wiring + Harness) where can I find a high quality one?
I also want my LED parking lights to match with the 6000k Garax Bulbs.
If you guys can help me out, I would really appreciate it ! Thanks in advance.
Forgot to Add: Does it matter if the Ballast is Slim or Normal size?
Old 06-14-10, 09:08 PM
acefalcon2
acefalcon2's Avatar
idk about garax bulbs in aftermarket HID kits... i am using Garax D4s... but yeah... you can get the hidkits from XenonDepot
Andre
Old 06-14-10, 09:09 PM
poorkidlol
poorkidlol's Avatar
Oh are Garax Bulbs only good for Lexus with OEM HIDs?
Old 06-14-10, 09:12 PM
acefalcon2
acefalcon2's Avatar
so far that i see yeah... and HID kits from XenonDepot comes with good bulbs anyway...
btw slim or not doesn't matter
ANdre
Old 06-14-10, 09:40 PM
poorkidlol
poorkidlol's Avatar
Okay so pretty much a high quality H11 HID Kit will be fine?
Old 06-14-10, 10:11 PM
xuningshen
xuningshen's Avatar
http://www.kbcarstuff.com/Volt_HID_6...s_p/vdp-6k.htm
i got the volt 6k HID kit, can't remember if i bought it off this site or not.... but its lasted me almost 2 years now and is still going, definately high quality.
Old 06-14-10, 10:27 PM
poorkidlol
poorkidlol's Avatar
Thanks for the input!!
Old 06-15-10, 03:37 PM
XenonDepot
Former Sponsor
XenonDepot's Avatar
poorkidlol,
Make sure to type in "CL" as the coupon code if you decide to go with the Volt kit to get a $25 discount.
As for the parking lights, a lot of ClubLexus members are using our 194 LED bulb (360 degree) bulbs.
ClubLexus members get a 15% discount on our LED lighting as well. All you need to do is type in CLLED as the coupon code.
Steve
Old 06-15-10, 10:15 PM
poorkidlol
poorkidlol's Avatar
Thanks XenonDepot
HID Low Beam 6000K = H11 6000k Volt Digital+ Xenon HID Conversion Kit
HID Fog Lights 6000k = 9006 6000k Volt Digital+ Xenon HID Conversion Kit
Parking Lights LED = 194 LED Bulb
This will make all my lights 6000k and will match 100% ?
Old 06-16-10, 05:33 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
Those are the right products to upgrade your IS lows, fogs, and parking lights :-)
Steve
Old 12-08-10, 10:15 PM
poorkidlol
poorkidlol's Avatar
FOR DRL I want Halogen instead of LED, what's my solution to match with the 6000k HIDS?
Old 12-08-10, 10:23 PM
SB350
SB350's Avatar
No matter what halogen bulb you use for a DRL, it will look yellow because it is the high beam bulb at 30% power.
Old 12-08-10, 10:30 PM
poorkidlol
poorkidlol's Avatar
thanks for the clarification but why do people buy colour halogen? so when they high beam it's a different colour?
Old 12-08-10, 10:54 PM
brociouz
brociouz's Avatar
I've seen people buy yellow high beams for the JDM look, but I have never seen someone successfully use a halogen bulb to match 6000K HIDs. I'm convinced it's impossible. If you want a match to your 6000K HIDs, get an LED DRL kit from V-LEDs or something.
Old 12-09-10, 07:07 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
poorkidlol,
I would not suggest going with LED bulbs in your DRL as they will offer you pretty much no light output. Some of our customers go with a performance halogen bulb (sometimes blue coated) to try and get a crisper output. However, You will never get a perfect match as one bulb is HID and one bulb is halogen.
Steve
Quick Reply: Another HID and Lighting qusetion.
