Mirror Issues!
I have noticed lately my mirrors will not stay where they are set. When I shut off the car and then come back later to use it, they are moved. I have to hit the memory every time to get the mirrors back to my setting. I have reset the FOB sync but it still does not stay where they were left. I also noticed that when I put the car in reverse the mirrors only go down partly (Less then halfway and not all the time) to the curb. I had the car in for recalls and the Stealer (Of course) could not recreate the problem. Has anyone else been having any of these problems?
Koz
Koz
If you want them to tilt down in reverse you move the switch to the left/right setting. If you don't want them to move you put them in the center position. That function works fine. The problem I’m having is when the mirrors tilt down they only move less then half way, intermittingly. I can move the switch while the car is in reverse and the mirrors will go all the way down, only when the switch is set to tilt (In left/right position) and select reverse they only go down partly. Also every time I get in the car the mirrors are not in the position they were in when I left the car. These problems have nothing to do with the mirror switch position (I don't think). The mirror memory is slightly moving the mirrors when I open the door. I’m thinking there is a problem with the sync function of the mirrors. There seems to be a separate problem with the tilt function.
Koz
I am confused, sorry to budge in with my own question ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
My mirrors (2010 IS250) only tilt half way in reverse, I can still tilt the mirror down while in reverse. I want the mirrors to be fully tilted when I reverse! How do I do this? I thought half way was normal, but my sister's RX350 tilts all the way down!
PS: It is stupid if I can't see the lines I am parking into.
I have the same issue. If you manually (with your hand) tilt themirror all the way up then all the way down then hit the memory button, it wors better. But you shouldnt have to do that to make it work right.
Koz
When it is working properly you can see the rear wheels and the curb. Of the total movement it moves about half way but its from half way (Where you have it set to see behind you) to the ground. What is happening to mine is, it is only tilting down about half of the normal tilt. I can not see the rear wheels. I think I need to make a special trip to the Stealer just for this problem and show them the problem instead of just telling them and expecting them fix it.
Koz
Koz
Koz
Koz
Add this annoyance to the Navigation lockout.
Up until a couple weeks ago when I put the car in reverse the mirrors would tilt down enough to see the rear wheels and curb. Now, they only tilt down about half of what it used to and I can not see the rear wheels.
I think what may be happening is the reference point that the system uses is not right. What I will do is put the car in reverse (With tilt switched on) and then physically move the mirror to where I can see the rear wheels. As far as the mirrors moving when I open the door, I don't have a clue. Possibly I'm not syncing the remote the right way. Hopefully I can save a trip to the Stealer.
The nav lockout is REDICULOUS!
Koz
Koz
