Problem with Headlight low beams...
I recently installed garax 6000k d4s bulbs and everything worked fine but after a few days the drivers side went out. I opened it back up and stuck my old OEM bulb and that did not light up either. So the bulbs are not the problem. I checked my fuses and they were all good too. Any ideas in what might be the cause? I noticed some slight condensation in that headlight housing as well... I hope I didn't turn a simple 100 dollar mod into a 500 dollar one...
I hope thats not the case... cause I'm not under warranty lol since I'm out of warranty I shouldn't worry about the aftermarket bulbs then huh
look on your manual it will tell you which one it is... my problem turned out to be moisture in the headlights because my seals were not on properly. These ignitors tend to be very sensitive and will not ignite even with slight moister in the housing. I dried them out for a couple days and they are working fine ever since
Panerai127
01-31-07 10:27 PM
