Oil change - extra oil and filter necessary?
Old 06-22-10, 12:35 PM
kmo19
kmo19's Avatar
Default Oil change - extra oil and filter necessary?
2008 IS250
When I take my car in for an oil change, they always charge for "extra oil" ($6) and an oil filter ($10). Does the IS250 really take more oil than other cars, and do I need a new oil filter every time?
Old 06-22-10, 12:38 PM
llamaboiz
llamaboiz's Avatar
its a rule of thumb, everytime you change oil you change your filter so, yes.
and yes our cars do take more oil than normal cars, but nowdays everyone takes more oil too, not the 'normal 5quarts'.
Old 06-22-10, 01:51 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
question: where did you get the oil change done?
Old 06-22-10, 02:28 PM
shadowman
shadowman's Avatar
It is a requirement that you change your filter when you change your oil. The filter is what traps the dirt and other particles that can damage the engine. If you disassmble an old filter you will see what I mean. You'll see tiny metal pieces and other junk trapped in the filter.
If you re-use your old oil filter, then it's like re-using toilet paper. Simple as that.
Old 06-22-10, 03:25 PM
pigeon83
pigeon83's Avatar
The IS250 takes about 6.5qts. All cars take different amounts of oil. There is no universal standard. Change the filter at every oil change.
Old 06-23-10, 10:58 AM
weenstan
weenstan's Avatar
If anything you should be changing the filter 2x for every oil change :P.
Old 06-23-10, 06:52 PM
ecr527
ecr527's Avatar
Do you have to change the filter every time you change your oil? Absolutely not. Should you? Oh yeah!!!!
The place you took your car probably advertises their oil change price for a 4 cylinder car.
azncapcom
06-15-20 06:51 AM
USCRugby
04-21-13 10:52 AM
stvincent
IS F (2008-2014)
21
01-27-13 11:41 PM
lilbluu
06-01-10 03:44 AM
wakaru8
12-23-09 08:07 AM
Quick Reply: Oil change - extra oil and filter necessary?
