IS250 hard "jerk" when put in D
These engines are direct injected. The initial cold idle RPM is much higher than what most people including myself are use to. So that is my guess as to what people would complain or have concerns about it.
I had the brake dust TSB done too. The new pads seem to be less "sticky" then the OEM dust storm type. By "sticky" I mean less intial bite. I just remember to press the breaks a bit harder then with other cars. This aviods the car jumping forward, lurching etc...
It's your car, drive it like you want too.
well...I really don't care how I warm up the car, but I'm more concerned about this harsh jerk when I shift the gear in D. Since it doesn't happen when it's warmed up so i'm gonna try to let it sit for a while before I drive. If that doesn't help then... dealer time...? Or is this a normal thing...? I just wanna know if this is a common problem because it seems like it has happened to some of u and it didn't to some others.
"Idling is bad for a car." How? Do you turn your car off when you stop at a red light? Idling doesn't hurt anything, engines just put out more emissions at idle and they are more efficient at higher RPMs. This is why we have an EGR system, but the OP is about a feeling from the transmission. So, if idling is bad for a car, then why don't our cars idle at 3,000 RPM?
"Keep rpms under 3k or so until the temp guage goes up." And where is this transmission temperature gauge? Or are you thinking that the engine coolant gauge tells you how warm the transmission fluid is? Engine coolant and transmission fluid warm at different rates, so the coolant gauge is not relative.
If you have ever been a mechanic, or if you have any experience working on cars, you know that automatic transmissions always work better when warm and act up when cold. The OP even stated that this condition only happens when its cold, and doesn't happen when its warm, so what does that tell you? What do you think the dealership will tell him? Idling is bad for a car?
Myth #1: The engine should be warmed up before driving. Reality: Idling is not an effective way to warm up your vehicle, even in cold weather. The best way to do this is to drive the vehicle. With today's modern engines, you need no more than 30 seconds of idling on winter days before driving away.
Myth #2: Idling is good for your engine. Reality: Excessive idling can actually damage your engine components, including cylinders, spark plugs, and exhaust systems. Fuel is only partially combusted when idling because an engine does not operate at its peak temperature. This leads to the build up of fuel residues on cylinder walls that can damage engine components and increase fuel consumption.
Source: http://www.consumerenergycenter.org/myths/idling.html
More articles/links:
http://ezinearticles.com/?Should-You...ng?&id=1975316
http://www.dslreports.com/forum/r235...her-Dont-Do-It
I couldn't find any articles that say you need to warm up your car for 1-2 minutes or more. 20-30 seconds at most (in the winter), and many say even that's not necessary since the advent of fuel injected cars.
Anyone on the other side of the debate care to share their sources for why our cars need 1-2 minutes of warm-up time?
A car is like a human body. Once we get up we have our own routines before we get started right??! so does your car! even with a 1 to 5 minute warm up is better then nothing. its like when we pump 91 or 93 octane, we have to continuously inputting the same fluids into our cars.. any unusual product into our cars or body, we will only know and define whats whats wrong. like doctor checkups, just bring it into the dealership to have the problem resolve. lol
Wow, the problem is not whether you are warming up your car are not, because the bottom line is you DO NOT need to, and it is bad for your car. Please don't listen to anyone that says otherwise.
The problem is your transmission mounts. They are worn and need to be replaced, which is why you feel the jerk when putting the gear in D.
http://autorepair.about.com/b/2009/0...r-your-car.htm
This is the second link on Google on the same topic It states the exact opposite.
Also, do a Google search for "automatic transmission problems when cold" and see what you find....
We will always get different answers on the internet to the same question, all I can do is give out my own technical knowledge and my experience of being a mechanic.
Back to the OP question, I suggest at least try and let the car idle and warm up for about 1-2 minutes...if that works, then great ...if not, then go to the dealership.
If the issue is with the transmission mount, then why would it only happen on the initial cold start? If the mount is bad, wouldn't it do this every time?
This could just be masking the true problem though. Wouldn't the OP rather fix the problem rather than find a workaround? That's like telling someone who hears clunking sound when turning left to just always turn right instead.
