recharging AC
its r-134a...freon isnt allowable by law anymore i dont think. I seem to remember the low port being tucked away down low in teh engine compartment but i could be wrong. Do you have the correct guages?
You want your low side pressure to be around 32-35 as a rule of thumb.
ok, i was able to find the LOw port. its located on the driverside near the top of the engine.
i believe i do have the correct guages, however when i turned on the car and started to recharge, my guage was reading around 120, no where near 32-35. Can anyone else confirm if the pressure is suppose to be aound 32-35
nvm, thanks guys, the reason my guage was giving me bad readings was because it only read one way. I was able to refill completely drain my car and refill with the correct pressure readings.
yes my car is out of warranty, and i do not have a leak. i just wanted to refill because for some reason i thought my ac wasnt blasting cold enough, so i had assume i had a leak. in the end, after all my work, my ac blasts exactly the same haha, i fail
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
shuiyuan
02-23-08 10:51 PM
