V-led DRL HELP!!!!!!!
The Fog Lights are not affected by this problem as they run at full voltage. This problem only occurs on cars that use a low voltage High-Beam for the DRL.
I hope this helps to clarify these problems.
James
Hi I just bought the V-LEDS DRL Kit but no instructions was included. Could someone help me clarify which end goes where? I don't want to chance it and blow a fuse or cause permanent damage. Please see picture of the new V-LEDS harness for the DRL. I'm not sure how to run or hide the harness. Thanks
That looks about right, you will left one factory connector un-connected, and may want to put tape on it to prevent from getting wet. But, with the relay, you will have to drill holes on the light cover on each side unless you do not plan to put the cover back on.
http://vleds.wordpress.com/2010/11/0...-is-drl-guide/
Thanks! I couldn't see how to make all the connections work but it make more sense now to leave the driver's side factory harness unplug. I will try to find some time this weekend to do this. Thanks again.
Wow I wish I had seen this thread before my install of this v-led kit ....It also didnt come with any instructions. So I had to guess at the install. After I got everything installed. I tested it, then boom!....my little DRL module blew up..... I hope vled will send me a new DRL module.
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
Thanks but I got V-LEDS Tech Rep to clarified for me. Here is my diagram.
I tap the ground to the spot by the battery fender and run the harness along the side to hide the wiring.
One of my buddy mess up his Accord V-LEDS DRL Modules. You can tell when the DRL module is plug in wrong because it will heats up really bad. He say the plastic housing was melting. Just in case, I double check the positive and negative wire of the module and correspond it to your harness positive/negative wires. You can pop the DRL Module cover off (its will snap to close). For the future DRL Modules, V-LEDS should use red/black wires to help us easily identify the positive/neg terminal.
I think the link on the first page is it.
However could someone clarify for a newbie...
This is the link for both DRL and FOG lights?
http://www.v-leds.com/Exterior-LED/D...22474-3-3.html
are there any cheaper alternative?
http://www.v-leds.com/Vehicle-Specif...71399-3-3.html
isnt this what we need?
Question: If I buy the above kit.... I lose high beams right?
