My LC818 are.....
My LC818 are.....
Chewing up my passenger side front tire. Im lowered on S Techs and sometime when i hit a dip or something ill hear it but not till today did i see the damage. What can i do???
YOU'RE SCREWEDDDD!!!! END OF THE WORLD!!! AHH!!!!
JK. Check your alignment and make sure all your bolts are on correctly too. You're probably just misaligned. If you hear a clunking it might be a bolt on your sway bar endlinks. Happened to me. Easy fix.
Post pics of the damage. If it's only rubbing on bumps, I can't imagine it being that bad.
Here are your options:
1. When you get new tires, get a smaller size.
2. Get coilovers
3. Get an alignment and hope that fixes it.
4. Roll or shave your fenders (assuming that's where the rub is happening)
2. Get coilovers
Got my alignment done and the front passenger side is still trashing my wheel when i hit a dip. Im not sure what else I can do, Didnt have any problem when i had my F Sports, i guess the offset is the cause of this, any more suggestions???
