Trying to install my my 20mm ichiba v2 spacers on my 350. first i put on the hub ring, gentle got it lined up with the bearing then tried putting on the spacer but it refused to go in. ok so now i tried putting the spacer on first and then the hub ring, but now it wont sit flush with the spacer. whats the technique everybody is doing?
nevermind it was a lot easier to get put the spacer on first then slowly tap in the hub ring then proceed to torque them down to 85ft/lbs. so far no vibration, no rubbing, and drives like stock.
