Oil GUSHING out of the filter housing?!!?!
So....i just changed my oil. Everything was tight. O rings were in place. I cranked it up and brought it down off the ramps only to realize that ALL of the oil was gushing out of the filter housing.
So now I've got a gigantic oil stain and no oil in my car. I'm really concerned here, because everything appears correct.
any ideas?
any ideas?
no, definitely not my first time. Which is why im taken aback by such a disaster.
Im thinking o ring wasnt in place either, but I checked it TWICE! When I loosen the filter housing again, the oring was exactly where it should have been.
ok, well......oil is changed. I dont know how or why the first time I tightened the filter housing it went bad. Like I said before, the o ring was in the right spot the whole time. This time it took, so I wont complain.
Coming up next, DIY oil clean up!!! Stay tuned.
Did the o-ring fit tightly or very loose? If it was loose, the thread might have cut it. I bought a filter set from O'reilly and the o-ring didn't fit right. So I used the o-ring from oil industry. I'm working in oil service industry so I'm pretty familiar with o-ring design and usage.
well the one from the replacement filter was very loose. So i just reused the one that was on there after I inspected it for any problems. It still felt and looked just as good as the new one that didnt fit right.
I really dont know what could have happened, except that the o ring slipped out of its notch when I tightened it then slipped back into the notch as i took it off making it appear as if everything was correct.
Thats the only thing I can come up with.
A good rule of thumb from oil industry: Never reuse o-ring that was used for high temperature application. High temperature would decompose the o-ring.
In your case, however, you did check the o-ring before hand so I'm not sure where the failure point is. Perhaps, you didn't check the o-ring carefully or tighten the cartridge strong enough. Just guessing...
Glad I saw this. My wife's is250 just started gushing oil today. I noticed it when I moved her car--there was a trail of oil following me around.
After removing all of the 50 screws holding on the plastic armor belly pan, I saw the culprit--the f-ing oil filter.
Is it strange that it would start leaking on its own? Never was a problem before today.
Heading to the shop in the morning to pick up a new oil filter / O-ring so that I can replace everything this weekend.
This happened to me last time I did my oil/filter change. I wasn't paying attention and the O-Ring shifted out of place. When I did my final check before turning on the engine everything was fine...but once the engine was one it was gushing oil all over my garage floor.
Glad everything turned out to be okay with yours.
Merkur Fanatic
