Need input: full ings+1 kit on obsidian with HKS hi-power
I'm thinking of picking up a new full ings+1 kit from a member on here. I wanted to know where I can find a good quality picture of the kit on a obsidian is350. Also does anyone know if the hks hi-power exhaust would fit the rear skirt because I can't tell how big the exhaust opening is on the ings+1 rear.
I was looking into the wald full kit. The ings kit looks more like VIP style and I'm not sure if I want to go that route. Since the member on here is selling it at a pretty decent deal I might go with the ings kit. Plus I don't think many have the ings kit on a obsidian is350.
Open to other suggestions as well.
Thanks
via iPhone
Thanks
via iPhone
You can find some pictures of black INGS+1 here
https://www.clublexus.com/forums/is-...-bodykits.html
Thanks
Thanks for the pictures. I must of missed it while searching on the phone. Where did you find those pics Josh?
Likwid - are you talking about the ings rear with the hks hi-power exhaust? If so do you have a picture? Or are you saying if I have the ings kit and go lower I would need to shave it so it doesn't scrape?
Thanks
Thanks
I have the Seibon rear which uses the same mold as the INGS. The only issue is that my HKS Hi-Power rested against the lip, causing an annoying rattling noise. But the noise eventually went away as the exhaust chipped away at the lip. ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
You can't see it unless you get under the car.
That means I'm going to have to trim/shave the exhaust ports on the ings rear to make it fit. I was hoping the opening would be like my gfx rear since it fits nicely with still some gap so it doesn't melt my rear lip. Not sure if it's worth it to do that to make the exhaust fit and not worry about future damage.
This should provide a good visual. The affected area is where the blue tape is in the picture.
![Need input: full ings+1 kit on obsidian with HKS hi-power-0072.jpg](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/181309d1461112034t-need-input-full-ings-1-kit-on-obsidian-with-hks-hi-power-0072.jpg)
sry i was quickly using the iphone at work today... i had to triim it a bit, i have a ings and hks hi power.
pretty much what montgb showed, all i did was shave it down and u cant even tell its there unless ur laying on the floor
Thanks
BPauto
RC F (2015-present)
112
01-03-17 10:56 AM
