My new oem look
Old 05-02-11, 05:05 AM
  #106
dubsesd
dubsesd's Avatar
Bought centercaps for 99 cents on eBay lol
10 dollar shipping from china
Old 05-02-11, 08:59 AM
  #107
CCJ22
CCJ22's Avatar
Link to the ebay seller?
Thanks Dub
Old 05-08-11, 01:12 PM
  #108
CCJ22
CCJ22's Avatar
O hi there. I have a question.
See post 107
Old 05-09-11, 09:33 PM
  #109
slade037
slade037's Avatar
Any chance to get those pictures in a higher res for a wallpaper?
Old 05-16-11, 03:27 PM
  #110
viprtwo
viprtwo's Avatar
what hubcentric rings did you use?
Old 05-16-11, 09:24 PM
  #111
CCJ22
CCJ22's Avatar
See post 107
This! x2
I'd like to know too. More importantly did the wheels match our hub or did you have to use rings?
Old 05-17-11, 04:49 PM
  #112
fknISC808
fknISC808's Avatar
This! x2
you do not need hubcentric rings for these wheels. they bolt right on no issues.
Old 05-19-11, 03:10 AM
  #113
CCJ22
CCJ22's Avatar
My confusion has overtaken me.
To clarify you mean that the genesis coupe bore centric diameter matches ours?
Cause if there's is bigger then that makes sense that they would "bolt" up to ours but I'd rather not have a wheel resting on just 5 lug nuts. I'd also like it to rest on my hub bore
Old 05-19-11, 11:15 AM
  #114
SPNinjA
SPNinjA's Avatar
Hi,
I currently have the Genesis wheels on my car right now. When I got them installed, the mechanic asked if I had any hubcentric rings. I asked if I really needed them and he said no but, that they are recommended for any aftermarket wheels. I was still a little unsure so I bought a set of polycarbonate rings off eBay. I'm going to put them on whenever the weather clears up around here. I'll let you you know.
Old 05-19-11, 09:44 PM
  #115
CCJ22
CCJ22's Avatar
Thanks for keepin us informed.
Old 05-19-11, 10:36 PM
  #116
IS144
IS144's Avatar
Originally Posted by flektone
sorry to say and i know this is all a matter of opinion and taste. But the Hyundai Genesis coupe has a better body then our cars. Only reason I didnt buy one is because I cant get over the fact its a Hyundai. If that car was a audi, infiniti, acura or even honda people would be buying them up like crazy.
You couldn't GIVE me a Genesis. that thing is a tin can....putting the wheels on the Lex did them justice.
I love the OEM look.....
Old 05-23-11, 04:55 AM
  #117
CCJ22
CCJ22's Avatar
So according to the genesis forum The genesis coupe hub bore is 67.1mm... And I think ours is 60.1mm. Not completely sure on either as I haven't measured either hub bore.
But if this IS true then I'm in wonder of how exactly the OP has no vibration? Anyone with these wheels should, imo, get hub rings for these genesis wheels.
Old 05-23-11, 09:00 AM
  #118
SPNinjA
SPNinjA's Avatar
Alright, so I tried putting on the hubcentric rings yesterday. I had to shave off a little bit of the ring to get it to fit in the wheel. I then tried putting my wheel back on but had trouble getting them to fit on correctly so I just took the rings off. Haven't heard of anyone using hubcentric rings for these wheels and I honestly think the fitment is a close match without them. Also, I have not experienced any vibrations on these wheels.
Old 05-24-11, 02:59 AM
  #119
CCJ22
CCJ22's Avatar
Thanks for chiming back in.
So to wrap my head around this you had 67.1 outter diameter hub ring w/ a 60.1 inner diameter and it wouldn't fit when you attempted to put that ring inside the genesis 19" wheel?
I'm wondering if in fact the ring should have been a 67.06 measurement???
Where did you get your hubcentric rings from?
Did you clean and brush the inner hub hole on the genesis wheel with a wire brush to clear out all debris prior to attempting to insert the hubcentric wheel?
Lastly, how much did you get the genesis wheels for?
TIA!
Old 05-24-11, 10:18 AM
  #120
SPNinjA
SPNinjA's Avatar
TIA!
I got these rings off of eBay "HUBCENTRIC HUB CENTRIC RING RINGS WHEEL RIM 60.10 x67mm". I did not clean around the hub (probably should have) I don't know if it would have made a difference. It just wouldn't sit right. And I got the wheels for $500 shipped (a steal)... Just search around on the Gencoupe forum.
Quick Reply: My new oem look
