My new oem look
#121
So according to the genesis forum The genesis coupe hub bore is 67.1mm... And I think ours is 60.1mm. Not completely sure on either as I haven't measured either hub bore.
But if this IS true then I'm in wonder of how exactly the OP has no vibration? Anyone with these wheels should, imo, get hub rings for these genesis wheels.
With that being said, it is recommended that you get hub rings to avoid possible vibrations. I like to be safe, so I would get them, but many people dont.
#123
^^if he ran 235s in the front and 255s in the rear his overall rolling diameter will be way off, by using the same size tires he minimizes the rolling diameter difference which would make it ok for an AWD to run staggered wheels
#124
For me on the other hand with RWD 250, I can safely go 225F/255R without rubbing which is what I am after. Thanks!
#125
Hi Guys... I have some questions about the is300...not 1st... im talk about second gen...
im new on lexus and bought my is300 for a month...
I just want to know that is300(gulf edition) has any type of tpms sensors!?
i bought genesis coupe 19" oem rims last week and i want to know that the tpms sensors work on it by a plug and play or bad luck i must have some tpms error on my screen for ever!?
and any one has changed oem rims with aftermarket ones... does it have any problem on lexus !?
Another Question :witch size of tire i must buy for my rims... there is no drop option in my country and if i want to drop my car its so hard to drive it on our poor roads,,, (if i want to drop i must order parts from another country) i dont want to do any fender works,,, is it need any spacer!? and What Kind Of Spacer And Witch Size...!!?
there is no customer service in my country... Means no service and every thing must be DIY...
Thanks For Help Me To Improve Myself...
#126
1. If you installed your Genesis wheels and are getting a TPMS error, you will need to pull them out of your stock set and have them installed in your Genesis set. They will work with stock TPMS. As far as aftermarket wheels, you would have to check if they are TPMS compatible before you buy.
2. 225/255 tires will be fine
3. you do not need spacers
Hope this helps. Aloha \m/
#127
Welcome to CL and congrats on your purchase.
some where i heard its caliper maybe have a little smash with front rims....
and another question,,, will tpms system have the spare tire!? means the spare tire has tpms system!? no problem with spare tire... the pressure of all tires will not same together!!!
thanks...
#128
Thanks for your useful help...
thanks...
thanks...
I do not know if your model has the 350 brakes or the 250 brakes. If its the 250 brakes (Smaller) than you will be fine, not sure if the other member in here put it on with the 350 brakes. As far as I know, you only have 4 sensors, none in your spare.
#130
I think its the big one and it about 2 or 3 mm space between caliper and rim on front... (have a cover too)
No 5ft sensor!!! happy for that,,, and lot of thanks for your help ...
Added,,,
just use oem genesis coupe rims wheel cap....
use a knife to remove the hyundai layer from the cap( take care your hand) its easier to heat it,,,, then use sand paper to remove the hyundai plastic...
now paint it,,, and take a decals on it... enjoy from your stock cap...
i do it by myself...
#132
I really like them...I wanna get some...just need to see whats up with the center caps...why didnt he use them( or was it because they had the hyundai wings or the H on them)...why cant you just take that off...maybe replace it with the lexus L
#133
Thanks Bro.
Added,,,
Added,,,
Right on! Good to hear. Start up a thread when your done
there is another thread SPNinja started too and someone was asking the same question. From what I can recall, Lexus ES center caps fits nicely.
#135
So this is what i done...
i used Hyundai Center Cap
i removed the hyundai layer with a screwdriver...(you can use a knife instead)
take care don't brake it with high pressure of your hand...
you can warm it to remove the tape easier
now use your fingers to remove the tape...
after removing the Hyundai layer you must use rubber to remove H shape from the center cap...
don't let the rubber go to basic layer....
after that use a sand paper to get it smooth
now use a softer sand paper to get it more and more smooth...
(take care of edge)
now use a spray color to paint it if you want a decals on it
after paint let color to dry... now use your decals on it...
if you want to use your L logo you can buy it from a shop and use tape to take on it....
Enjoy it...
(take care of edge)
Enjoy it...
