Water Pump Replacement.
Old 02-10-18, 12:29 PM
  #46
Zmon
Zmon's Avatar
Originally Posted by Kristib
It appears that the Lexus water pumps need to be replaced between 50-75k miles....interesting. I need a water pump replacement, thermostat, gasket and drive belt per the dealer. I found all the parts but have what may be a dumb question. When the dealer says drive belt, are they referring to the V belt, timing belt, or ? 2007 Lexus is 250. Thanks
Meh, YMMV with the water pumps. Mine didn't start leaking until around 125k.
They're referring to the serpentine belt. These cars do not have timing belts; they have timing chains. If you're on your original belt, I'd change it. The belts are one of the more neglected things people don't change on cars. Heat, mileage, and age all take a toll on the belt. If any of the groves appear to be cracked, it's time for a change.
Old 02-11-18, 01:57 PM
  #47
StanleyR
StanleyR's Avatar
Is this mostly an is250 issue or shared with the is350 as well?
IIRC the PO of my car had it replaced while under his ownership
Old 02-11-18, 04:31 PM
  #48
Aspect
Aspect's Avatar
2is general issue
Old 12-27-18, 07:56 AM
  #49
motoxxx
10th Gear
motoxxx's Avatar
Hi ClubLexus,
I have an 2008 IS250 with 130K miles with original water pump and serpentine belt. I checked it every time I do an oil change and everything looked fine. Should I replace it now or wait until it start going bad? Thank in advance. Chris
Old 12-27-18, 08:32 AM
  #50
primavera
primavera's Avatar
If it ain't broke, why fix it? With 130K miles I'd change transmission fluid more than anything else.
Old 12-27-18, 08:34 AM
  #51
motoxxx
10th Gear
motoxxx's Avatar
Already did it. Thanks!
alchemist
07-21-21 12:24 PM
usermel
07-10-19 02:18 PM
GX763
GX - 2nd Gen (2010-2023)
02-22-19 11:02 AM
Ants350
05-15-14 11:56 AM
Colpup ES3
11-09-07 04:26 PM
Quick Reply: Water Pump Replacement.
