Iphone4 and bluetooth :(
Old 08-02-10, 08:35 PM
IS250Slvr
IS250Slvr's Avatar
Default Iphone4 and bluetooth :(
OK , I got my Iphone4 i synced it to my 2010 IS250 , syncs fine adds all the contacts my problem is when i click bluetooth audio it says the player is not found check player setting Can anyone help me out ??? i am bummed i cant play my music Help
Thanks
Old 08-02-10, 09:29 PM
projectdna
projectdna's Avatar
iirc, you can't stream music via bluetooth from your iphone to the 2is sound system.
you'll need an ipod adapter kit or a vaistech/DICE unit to do that.
Old 08-02-10, 10:21 PM
nitrotang
nitrotang's Avatar
Can the Bluetooth in my 2006 sync contact information too?
Old 08-02-10, 10:25 PM
kslater
kslater's Avatar
I Beg to differ. My 10 IS250 IS working just fine with my Iphone 4. I can stream music over bluetooth as well with no problems at all. To the Op, what steps are you taking when trying to pair the phone with A2DP?
Old 08-03-10, 06:59 PM
IS250Slvr
IS250Slvr's Avatar
I set up a new phone on the navigation It connects the bluetooth and allows me to transfer contacts but when i go to audio and click on BT i press connect and it waits a moment i then it says audio not connected check you audio setting on device???
Old 08-03-10, 07:38 PM
marshjr
marshjr's Avatar
Not true.
I have no problem at all streaming music to my 2010 IS? Use it every day...
Not hatin', just sayin'...
Old 08-03-10, 07:39 PM
MBTC
MBTC's Avatar
Not true in his case since, he has a 2010, they do support streaming bluetooth audio (and it sounds fantastic, check my thread on iPod Touch + Bluetooth Audio).
To the OP, it should be the same with the phone as it is the iPod touch. You just have to pair them.. But remember the BTA to the stereo is not the same as the phone Bluetooth. Its easier to conceptualize in my case because I have a separate Motorola phone paired with the hands free phone, and an iPod touch paired with the stereo for music. In your case I'm guessing you need to pair twice, even though its the same device it could be two.
Old 08-03-10, 10:08 PM
kslater
kslater's Avatar
Yes, you must pair twice. Go to the audio bluetooth settings at pair it.
Old 08-04-10, 06:09 AM
IS250Slvr
IS250Slvr's Avatar
I will give it another shot if it doesnt work maybe i can call you and you can walk me threw it
Old 08-04-10, 09:31 AM
javyLSU
2IS OG
javyLSU's Avatar
^This. I had a 2010 loaner a few weeks ago and the bluetooth A2DP streaming works perfectly (once paired).
Javier
Old 08-05-10, 08:17 PM
IS250Slvr
IS250Slvr's Avatar
Ok, so i started from the beginning i first Synced the phone through BT after it has connected i transfer all my contacts, then i click on Audio press BT audio then it shows BT is not connected i press connect it tries to connect then it says BT audio not found check portable player setting ???? Any idea
Old 08-05-10, 08:22 PM
MBTC
MBTC's Avatar
I know I had to put in passcode of 0000 when I did mine. I don't remember details, the voice prompt walked me through it -- it was pretty straight forward with the iPod Touch, not sure if its the same with the iPhone or not. The car owners manual should get you there.
One thing I do remember, it said I may need to re-pair my phone after doing the BTA, but in my case I did not. So since your audio and phone are the same device (mine are not) you might try unpairing the phone, try doing the audio first then the phone? Just an idea.
Old 08-06-10, 12:06 AM
DaKi3241
DaKi3241's Avatar
OMG hearing all this is like a dream... technology these days is so advanced!
I just got the iphone 4 and question now is.... what are the features for a 2007?
All i know is phone pairing. Can i do anything like stream music? or import phone book? this is all very new to me
Old 08-06-10, 01:37 AM
CLIS250
CLIS250's Avatar
same gotta 09 though. what can be done?! i already have an ipod interface but it doesnt fit as that stupid bumper case doesnt allow the adapter to be plugged in. so i might just run raw.
Old 08-06-10, 09:26 AM
vicc101
vicc101's Avatar
I have 2010 IS and when I set mine up, the car's system set up the phone and media at the same time. You also might want to check the phones bluetooth settings. I have a Droid and it gives you an option to use bluetooth with either phone audio or media audio. DROID DOES...iPhone dosn't.
Quick Reply: Iphone4 and bluetooth :(
