3-Piece Wheel Disassembly and Polish/Refinish with drilled TPMS Holes
So I decided to take apart my wheels and refinish the faces and clean up the corroding chrome lips.
Also repolished the inner barrels since its been 2 years since I clean and polished them.
So before I start, here are the pix of my TPMS holes I drilled into the wheels about a year ago because I was getting tired of the sensors coming loose from the straps and the idiots at the tire places always breaking the iForged style valve adapters by over tightening them.
I used a 7/16” drill bit to drill the holes
![](http://images56.fotki.com/v713/photos/6/60797/4677200/SDC16919-vi.jpg)
![](http://images112.fotki.com/v590/photos/6/60797/4677200/SDC16920-vi.jpg)
![](http://images17.fotki.com/v313/photos/6/60797/4677200/SDC16921-vi.jpg)
The hole is directly opposite of the original valve hole for balancing
![](http://images12.fotki.com/v200/photos/6/60797/4677200/SDC17032-vi.jpg)
Faces removed from the barrels…I used some bolts and nuts to keep the lip and barrel together so I wouldn’t have to break the seal and reseal them.
![](http://images14.fotki.com/v1628/photos/6/60797/4677200/SDC17020-vi.jpg)
![](http://images56.fotki.com/v1601/photos/6/60797/4677200/SDC17028-vi.jpg)
Faces
![](http://images54.fotki.com/v1616/photos/6/60797/4677200/SDC17039-vi.jpg)
Stripping the paint from the faces for polishing.
![](http://images54.fotki.com/v104/photos/6/60797/4677200/SDC17058-vi.jpg)
Slight polishing…not the finished product. Forgot the polished face prepaint pix.
![](http://images55.fotki.com/v605/photos/6/60797/4677200/IMG_0383-vi.jpg)
Painted metallic gunmetal
![](http://images43.fotki.com/v504/photos/6/60797/4677200/SDC17331-vi.jpg)
![](http://images17.fotki.com/v326/photos/6/60797/4677200/SDC17332-vi.jpg)
Color matched TPMS nuts while I was painting
![](http://images54.fotki.com/v514/photos/6/60797/4677200/SDC17318-vi.jpg)
More pix when I am done with the clear coating the paint and polished faces. Paint is currently drying and the wife has banned me from spending every night in the garage after work.
Faces
wow you have *****, i would be scared to do that to my iforged wheels and then drive on them, was it hard to take them apart, i need mine polished as well but i think i might pay someone to do it.
unscrew all the rivets and then tighten them back, to what specifics (torque)
yeah i feel you on the TPMS adapters, Discount Tire screwed my adapters up as well by overtightening them, so I just went with a regular valve stem.
Also you should consider that there are 40 bolts per wheel...the chances of any one of them failing and causing the wheel to come loose is slim. There is 40 bolts for a reason...redundancy.
The centers, lip, barrel are a precision fit...they will be centered once you match them together.
do u guys really think these wheel companies actually torque the bolts to spec? HELL NO. they usually take out the impact gun and shot them all in. how do I know? I've been around it.
