New Product: VAIS Tech SL2iC
#136
monitor I view (tv, computer, phone)is high definition, I worry over whether I should wait for ML+--which promises both upgraded video and sound? I saw your post saying sound was way better than playing IPhone music through Aux cable---can you provide a quick assessment (as best you can) of video quality? Thanks.
#140
the following exchange with VTech on the SL2iC Vaistech forum.
My question: "I have a 2008 ES 350 with Nav. My install technician says that I would NOT benefit from the upgraded ML+ video over the video output of the SL2iC because the Nav screen on my 2008 does not have high enough resolution to show that improved video quality---that regardless of whether I install a Sl2iC or ML+, the video would look exactly the same on my 2008 Nav screen. Is this true?"
Vaistech's response:
"Actually your 5th Gen navigation screen does have a higher resolution, so you will see a significant video quality difference between SL2iC and ML Plus."
[end of Vtech response]****
Besides superior video, as indicated by VTech above, the Vaistech website shows that the ML+ has superior audio too (digital, not analog like the SL2iC). So, although*I love the fact that the*SL2iC *has the Navigation and Bluetooth unlock feature integrated into its hardware (and ML+ doesn't), there are other features of the ML+ that very much "call to me."
Plus Vaistech is currently developing "unlock" hardware (not software) for the ML+*which can be installed as add-on hardware, although it*won't be available until Spring 2011. (Vaistech's estimated*additional*hardware cost of that add-on is $150).
I really can't help but drool over the promised spectacular video and audio performance of the ML+. Kybbal says that the video is near HD quality on his*SL2iC; so video must be freakin' phenomenal on the ML+ (based on VTech's claims of superiority). *Also, ML+'s ability to hook up additional media XBox, or portable DVD player, for example) through its USB connection is very attractive to me, since I dont have built-in DVD player.
The downside of the ML+ is its way larger total cost of purchasing and installing first and second stage hardware. *($100 more than SL2iC for original hardware, estimated $150 more for adding on hardware to unlock Navigation and Bluetooth (when it comes out) plus the additional cost (approx $150) for the "second stage" installation of that unlock hardware. I have to ask myself: *is the ML+ WORTH the $400 more I would ultimately be spending (over my cost of purchasing and installing the SL2iC)? *I know I could shave $150 off that ML+ cost by waiting until the Spring 2011 to buy both ML+ hardware components at the same time --thus saving the second installation cost of $150--- but I am very impatient to install hardware now so I can see/control my IPhone's iPod songs on my Nav's screen. To heck with waiting 3 or 4 or more months longer !! *I'm also very impatient for Nav screen unlock, but I guess I could wait 3 or 4 months to add that, if I do go for the ML+ install now.
Can anybody think of more reasons why ML+ is worth the added cost to me? (I know many of you guys are doing your own installs, so "second stage" installation cost (for the add-on unlock hardware doesn't apply in your situation--but I am a woman who is technologically challenged; no way could I handle either the original or upgrade hardware installs myself.
Thoughts anyone?
#141
Thoughts anyone?
Thoughts anyone?
1) I am not expecting to see much delta on the video performance. If you play a DVD on a Gen 5 system (which I can do with my Mark Levinson system), you will note the video quality is good but not excellent. The ML Plus can't deliver better video than the Mark levinson DVD system since both are digital, and both are constrained by the 480P display. Anyone who says it is like High-def is mistaken - it's 480p. That said there may be an advantage in upscaling or downscaling with the ML Plus.
2) You will see a significant difference in audio performance (this is the sole reason I am getting the ML Plus). The hardware difference is $130 which is well worth the benefits of superior audio quality. With my analog SL2i-UP, I would rather listen to CDs than iPod. The digital ipod output should make the iPod sound great. I am assuming this is the case based on the VML vs. SL2i comparisons previously posted here.
https://www.clublexus.com/forums/lex...-feedback.html
3) If you already have PS override, then the cost of ML Plus is just the $130 delta between SL2iC and ML Plus. I personally wouldn't depend on Vais for the override, because the Vais override is activated by a soft-switch on the screen and requires you to use the Vais interface. The PS override is a physical switch that is much more accessible and much easier to activate and de-activate.
#143
really wish someone would post a proper review on this unit...
Can anyone confirm if the menu can be changed? If not, it seems the ML Plus gets a better layout of controls...
ML Plus Layout
![](http://www.vaistech.com/products/images/IMG_4007.jpg)
SL2iC Layout
![](http://www.vaistech.com/images/SL2iC-p1.jpg)
Can Vaistech confirm that the ML Plus has a better layout?
ML Plus Layout
SL2iC Layout
#146
My ML Plus shipped today and will be arriving on Wednesday and will have it installed Thursday afternoon. Will post a review.
I thought the ML plus was a no brainer:
1) Digital to the amp which means much better sound quality. I don't see point listening to analog inputs when I can listen to CDs. With ML Plus I won't give up anything in terms of sound quality.
2) The digital video will do a much better job of upscaling and downscaling. This is what causes good video to look bad. I think ML plus will have a visible advantage if the source and display resolutions don't match.
3) Don't need the motion override since I have PS override which is better.
4) Better controls
5) Ability to play non iPod sources.
4) Better controls
#147
Picked up sl2ic under group buy today.
Vais is near me so I went and picked it up.
Vais guys were top notch, and good service.
Review:
iphone 4
Jailbroken with Display Out from cydia
Install took abouth 30 Min. Programing was a breeze, but for some reason firstime only sound came out. After reprogram everything was smooth.
1. Audio quality is great. Although not a full digital interface, sound is far better than I expected.
2. Video Mode: Video quality is near DVD not HD(I was expecting this).
Under video Mode Due to My Display out function on the Phone, all the spring board and iphone content is displayed(good). All the apps including Tomtom navi works on display, and Music video playlist is also controlled via steering wheel under Video Mode. It's like having iphone 4 on your screen but controlled by your phone.
3. Navi, phone bypass works and it's not very hard to do so. Video unlock needs to be inputed every time you start(not hard).
4. User interface cannot be changed, and only position of the menu can be adjusted.
Overall I am very Happy with the purchase. Cost factor was a plus and Navi, Phone, Video over ride in one package is good enough reason for me.
Review:
iphone 4
#148
I really appreciate Batman75's detailed post. Lots of food for thought. This is exactly the type of personal, first hand input I was hoping for; although I was certainly a little crestfallen about his assessment of video capabilities in light of the 480p display limitation of 5th Gen Nav. Nevertheless, I have finally decided to follow Batman75's lead and order the ML+. *I also priced the PS unlock hardware Batman75 mentioned; but no way can I afford its additional $350 cost (for hardware alone) after spending the purchase cost of ML+, and its install cost. That'll be next Spring's decision (Vaistech add-on touch screen unlock of Nav and BT versus Prestigious Society's unlock switch.) It will probably all come down to which is less expensive at the time. For now, I've spent just about all I can afford to upgrade my Navigation system.
#150
I do think motion override is really important. It would be really annoying if you had to pull over everytime you wanted to change artist/album/video.
But the reason I wouldn't make this trade-off is because once you go for SL2iC you are stuck with the analog. I always found the sound quality on my SL2i-UP to be disappointing - It was okay, but I could tell it wasn't on par with playing CDs on my Mark Levinson system. And my MP3s are all loss-less.
So for me PS + ML Plus is the way to go. Otherwise I'd rather listen to CDs and Factory XM.
