Normal? Front Tires tilting when turned?
Old 08-07-10, 08:51 AM
kl323
kl323's Avatar
Default Normal? Front Tires tilting when turned?
Don't know how else to ask this, and not sure if my pics are clear... but is it normal for the wheels to tilt to the outer edge of the tire when turned?
I think first pic does better than the second at showing what I mean...
Thanks!
Old 08-07-10, 09:21 AM
kuuqi
kuuqi's Avatar
Yes it's very normal. When you turn, the vehicle tends to lean away from the direction of the turn. The tilted wheel allows the tires to create a great contact patch to the road under these conditions. Your car is 100% a-okay!
Old 08-07-10, 04:19 PM
brociouz
brociouz's Avatar
I remember worrying about this at first too, but it's totally normal.
Old 08-08-10, 07:10 PM
kl323
kl323's Avatar
Thanks for the heads up!
Old 08-08-10, 08:30 PM
edgeucated
edgeucated's Avatar
every car's wheel tilt when it turns
Old 08-09-10, 12:57 PM
ChrISF
ChrISF's Avatar
uhh thats not normal. you should get that checked out man.
btw, is this your first car you've ever owned?
Old 08-09-10, 03:58 PM
Bichon
Super Moderator
Bichon's Avatar
If he's ever owned a bicycle, the front wheel on that would do the exact same thing, for the exact same reason.
It's called caster angle. The reason the suspension is set up in this manner is so that the steering wheel will have a natural tendency to return to center when you let go of it, enhancing directional stability. Here is a wikipedia entry that should help you visualize it: http://en.wikipedia.org/wiki/Caster_angle
Old 08-09-10, 04:18 PM
kl323
kl323's Avatar
Yes I own other cars as well. It's just that the wheels don't angle out as much as the IS or they just weren't as noticeable.
Old 08-09-10, 04:27 PM
Bichon
Super Moderator
Bichon's Avatar
Sorry if the snippet I quoted came off sounding like "duh!!"; I thought you would enjoy knowing why the wheels tilt the way they do, and I've always found that thinking about the way the front end of a bicycle or motorcycle is set up helps to understand the concept of caster. (Which is one of the measurements you'll see when you have an alignment)
Old 08-09-10, 05:30 PM
kl323
kl323's Avatar
Bichon, you've mistaken my response! I actually appreciate that tidbit of information. I find it interesting and never knew of this phenomenon. I was typing on the fly and might have been abrupt.
Anyway, no hard feelings at all haha
Old 08-10-10, 04:43 AM
k2sty1
k2sty1's Avatar
i remeber worrying about this when i first got my IS
the steering wheel also has a "different" feel when u full lock
only car ive evenr owned before was a RX330 and that was a 4WD and i never really noticed it with those fat tires
P128sniper
03-27-15 06:01 PM
Rasengan
03-07-07 03:10 PM
Aristo94
GS - 1st Gen (1993-1997)
12-27-06 06:54 PM
DrShoe
12-06-06 03:11 PM
SGT
11-23-05 03:15 PM
Quick Reply: Normal? Front Tires tilting when turned?
