STOCK IS 350 1/4 MILE @ 5,860 Ft.
Actually you should be able to drop that 60ft time one to two tenths even at that elevation. Practice launching the car. I was able to get 2.19 60fts with my LS400 with 225/60-16s and an open 3.266 ratio differential.
Any time saved in the 60ft is often worth more due to the dynamics of acceleration. 1 tenth in the 60 is worth obviously at least 1 tenth and it is not uncommon to get more like 1.5 or even 2 tenths depending on the vehicles torque curve.
A little practice and you are turning 14s at WELL over a mile elevation and that is impressive.
The BEST solution for altitude is a waste gated turbo system. This is how piston engine aircraft maintain sea level power at altitude.
Next time out it will be in the fall and hopefully much cooler out...also maybe some suspension and exhaust by then as well
