IS mod/upgrade horror stories you know
i had my roof spoiler installed at a shop about 30 minutes away drove home on the highway boom off goes my spoiler the next time i self installed using 3m tape urethane and adhesive promoter its not going anywhere
I haven't done this to my newer IS yet, but when backing the headlights...
A) use a cookie sheet to avoid the "grilled" look on the back of the housings (clear part should be face up BTW)
B) when breaking the seal, take your time and do not touch the front of the housings. Getting that silicon back off that is a huge PITA.
C) if you get part of the way around and feel like you are using ALOT more force, put it back in the oven before you crack something
and almost forgot
D) DO NOT BE IN A HURRY TO PUT IT BACK TOGETHER. Otherwise you may end up with a FINGERPRINT on the freshly painted part of the housing. Will drive you nuts.
and almost forgot
Went to a so called great shop in the area n paid serious money for molding. N all that hit well the only thing that came out good is my molded wald trunk. Color match was awesome but forgot to paint part of my rear lip black and the mold job was medicore at best. Next time I want all my shot written down on paper on exactly what I want and dona walk around. Cause when i got my car back I had a broken stock exhaust. A ding in my door. Crack bumper lense. All the above
OH YEAH one BIGGIE here, everyone wants to run low with aggressive offset rims, then they mess up their front fenders their first day/first week they drop the car, is FAIL... hell theres plenty of guys here that should know better and are still messing up their fenders ![Slap](https://www.clublexus.com/forums/images/smilies/slap.gif)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
BUT I STILL RUNUMHARD!
Changed my front brake pads recently and then noticed my passenger side slide pin was seized. Did everything I could to budge it out, no luck. Then suddenly I remembered I forgot to re-grease the slide pins when I changed the pads last time around. ![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Rotors needed to be replaced and now having a seized caliper gave me a reason to finally go through with a BBK upgrade. If everything goes as planned, should be doing the change next week.
Another one I just thought of: a few months after installing Nokya 2500k bulbs for the fogs, the connector fried. After I had my tech repair it, I bought another set of Nokya 2500k bulbs, and of course the connector fried again. Fortunately, the connector was still usable so I am now running 3000k HID bulbs. I prefer the 2500k though.
I replaced my fog lights to yellow and didn't screw the driver side well enough. A few days later I smell something burning then I found out it was that bulb dangling and burning the plastic under the fender.
