Will those Wheels Fit an IS250 AWD - Part Uno
Old 01-29-13, 09:06 AM
  #211
gldcrzy
gldcrzy's Avatar
would i be fine running these?
work vsxx 18x8.5+28 ? the car wont be lowered at all? and if they are fine should i still run 225/40/18
Old 02-01-13, 10:23 AM
  #212
MonsterIS
MonsterIS's Avatar
does this ruin my awd system...? Can i fit these...?
F- 20x9.5_____ tire 245/40/r20
R-20x10.5____ tire 275/30/r20 +20 all the way around...
Old 02-18-13, 01:24 PM
  #213
chowsta
chowsta's Avatar
Non staggered, is this ok?
18x8.5 + 30 ___tires 225/35
Old 02-21-13, 06:48 AM
  #214
mr250
mr250's Avatar
will 19x8.5 235/35/19 and 19x9.5 265/30/19 work on a awd is250 the offset +30
Old 02-24-13, 01:49 PM
  #215
pmanliu
pmanliu's Avatar
19x8.5 +38 front
19x9.5 +42 rear
2 questions...
(1) From the looks of it, the rear will be pretty sunk in. What size spacer should i run?
(2) Also can someone recommend an AWD tire setup? Car will be dropped on tein s techs, and i would like to avoid rolling fenders. However i also need some protection against the NYC potholes.
Thanks!
Old 03-04-13, 06:41 AM
  #216
Scless
Scless's Avatar
18x9 +30 all around. Will this fit on my is350 without modification? Not sure if it matters but I'm at stock height right now.
Old 03-04-13, 10:27 AM
  #217
mr250
mr250's Avatar
on a 19x9+38 and a 19x10+38 will it be ideal to run a 235/35/19 for the front and 265/30/19 on the rear
Old 03-04-13, 10:54 AM
  #218
sm1ke
sm1ke's Avatar
Ideal in terms of the AWD system would be 235/35 front and 275/30 rear. But it's still less than a 1% difference, so you should be fine with 265s in the back if you want the extra tire-to-fender clearance.
Old 03-04-13, 10:55 AM
  #219
sm1ke
sm1ke's Avatar
18x9 +30 should fit. I'm not sure how far they would poke out from the fender though, if any.
Old 03-04-13, 10:59 AM
  #220
sm1ke
sm1ke's Avatar
Originally Posted by pmanliu
19x8.5 +38 front
19x9.5 +42 rear
2 questions...
Thanks!
I'd recommend a 25mm spacer in the rear for a flush fit. For tires I think you'd be safe with 225/35 and 265/30.
Here's a shot of 19x9 +25 with 225/40 and 19x10 +35 with 255/35 (not my car)
Old 03-04-13, 11:08 AM
  #221
mr250
mr250's Avatar
what tire size would be the best with a stretched on a 19x9/10.5 +20
Old 03-04-13, 11:36 AM
  #222
sm1ke
sm1ke's Avatar
I think people have done 215s on a 9. Not sure about 10.5 though.. maybe 235-245?
Old 03-04-13, 12:43 PM
  #223
mr250
mr250's Avatar
a 215/35/19 and 245/35/19 is -.82 will that be ok with the diff
Old 03-04-13, 12:52 PM
  #224
sm1ke
sm1ke's Avatar
That should be ok, according to other members. They say that as long as the difference between the front and rear wheel diameter is less than 3%, the AWD system can compensate.
Old 03-04-13, 12:53 PM
  #225
mr250
mr250's Avatar
awesome thanks
Quick Reply: Will those Wheels Fit an IS250 AWD - Part Uno
