Will those Wheels Fit an IS250 AWD - Part Uno
#256
Is250 awd here, looking To run a more Aggressive square setup
Planning To drop the car 24.5" fender To ground all Around
Wondering if i can roll with sa55m 19x9.5 +24 (square)
Anyone had/have same or similar setup? Im especially worried about the front
What Would Be ideal Tire Size? Dont want too much stretch since ill be running same in the rear
Thx in advance
Thx in advance
#257
Thx in advance
Thx in advance
Someone answer this man please I have a similar set up coming in today but +22
#258
^ trying to help.
I am currently 24 inches all around from ground to gender. I am on 19x9.5 et 30 all around right now. It was rubbing a lot but is less now due to shaving down/removing bumper tabs and bumper brackets.
I am planning to get spacers so I will be 19x9.5 et 30 in the front and 19x9.5 et 20 on the rear.
I think you will be okay with the +24 up front if you have already did the bumper tab work. Rears you will definitely need to roll.
I am running 235/35/19 tires. Hopefully someone with more experience can chime in and help you out. Good luck! Post pictures!
#259
I have an 2013 awd looking to put either fsport or h&r springs to lower. Will the avant garde m310 19" staggered front19 x8.5 offset 34 rear 19x9.5 offset 40 fit ok with out rolling fender. And will 235/35/19 front 265/30/19 rear be the best tire size? Thanks
#262
^ trying to help.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#263
so im dropped 2 inches on my 07 250AWD and ive been trying to order new wheels for so long, but i just dont understand the fitment.
My plan was to get 19x9.5 all around to avoid staggered rims. So now i want to figure out what offset to get to give my car the most aggressive fitment possible without doing any fender rolling
Thanks for the help!
#264
F - 19x8.5__40mm offset__tire 235/35/19
R - 19x10___45mm offset__tire 265/30/19
F - 19x8.5__40mm offset___tire 235/35/19
R - 19x10___38mm offset___tire 275/30/19
does anyone have a picture of their car with either of these setups?
#265
^ trying to help.
Are you AWD as well (seeing you have square setup wheels)? How's your cv boots liking the 24"? I assume you have nice roads where you're from
#266
Check my build thread.
#267
I am awd and I am indeed running a square set up. 19x9.5 all around with et30 at about 24" or lower GTF. Honestly I would play with the offsets to be on the safe side. My cv boots are still good *knock on wood* but all/most car's cv boots will wear out due to additional stress added. I check my cv boots everyday though. Haha. To be honest, where I am from, the roads are horrible. Potholes and crappy roads everywhere. I'm just being extra careful. ![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
#269
Looked through, but couldn't find the answer. Please help.
For AWD willing to put 19x8,5 (offset 35) all around with 235/40/19 tires. On stock ride height.
Will this setup rub in front/rear? Any mods needed
Thanks a lot!)
Thanks a lot!)
#270
I wanna buy the varrstoen es7 wheels. Will these wheels fit okay if I have a awd in h&r springs? I wanted to get the +22 offset staggered ones. Will 225/35/19 and 265/30/19 work fine? Do I need fender mods? I'm willing to at least roll my rear fenders but don't wanna pull them. H&r is a mild drop so I'm hoping it'll be okay
