Will those Wheels Fit an IS250 AWD - Part Uno
#271
I wanna buy the varrstoen es7 wheels. Will these wheels fit okay if I have a awd in h&r springs? I wanted to get the +22 offset staggered ones. Will 225/35/19 and 265/30/19 work fine? Do I need fender mods? I'm willing to at least roll my rear fenders but don't wanna pull them. H&r is a mild drop so I'm hoping it'll be okay
#273
#275
Hey guys,
I'm interested in putting the 19" G37S rims on to my 2006 IS250AWD.
The dimensions for the rims are:
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: 225/45/19 92W.
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: 245/40/19 94W.
Will these work with the 250AWD or will I have to change the tires etc?
#276
I'm looking for new tires but dont know what size. I want to know what tire size would look good STRECHED while maintaining the flush look. If need be I can always camber but I don't want to go no more than -3 seeing how my current tires only lasted a month at -5 camber.
Tire size currently: Falken 452's 245/35/20
Wheel size: 20x10.5 +25
Camber Kit: Arms are currently at set at 0
Natural Camber (from alignment sheet): -1
Lowered on H&R springs
Fenders have been rolled
![](http://oi40.tinypic.com/11hs8p3.jpg)
![](http://oi39.tinypic.com/2iixdy.jpg)
![](http://oi40.tinypic.com/2nbdci9.jpg)
![](http://oi44.tinypic.com/29zq2io.jpg)
#277
^^ For reference..
![Name: hellaflush-1.jpg
Size: 26.5 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/427918d1501333693-will-those-wheels-fit-an-is250-awd-part-uno-hellaflush-1.jpg)
Given how much the wheel pokes out, regardless of tire size, you're looking at more of a "hellaflush" fitment. You'll probably have to run -3, maybe -4 camber with a 235 tire stretched on the wheel. I'd suggest searching google images for pics of the different tire sizes you could run and go from there.
If you don't want to run a lot of negative camber, but you want the flush look, get wheels with a much less aggressive offset (+35 to +40).
#279
^^ For reference..
![](http://i18.photobucket.com/albums/b147/apswrx1/hellaflush-1.jpg)
#281
Hey guys,
I'm about to put on 225/45/ r18 on a 30 offset and I'm abit concern myself cos j have 1" drop.
#284
Hey guys I'm planning on getting new rims for my car pretty soon but have a few questions I've been struggling with. I want both my front and rear set of tires to sit as flush as possible with my fenders. So my question is can I run 18x8.75 with a 20mm offset in the rear and 18x8.75 with a 33mm offset in the front without any fender mods or rubbing? If so, what are the best tire size I would need to get? I have an AWD IS250 by the way.
