Will those Wheels Fit an IS250 AWD - Part Uno
#288
I am fairly new to the wheel game but I do know what I want to get for my 2IS . WORK Emotion XD9 but i don't know how to set it up . Help ? I don't wanna roll the fenders and I would prefer no rub . I will be going on coils , so if needed , i'll roll the fenders . I'd prefer not to use spacers , so i was going to go with 18x9 f 18x9.5 r , but i don't know the offset i should use , nor the tire size .
#289
Hi, im fairly new on this forum and i was wondering if this will fit my IS250 awd 08
Front: 19x9.5 +20 (with 245/40/19 Falken452)
Rear: 19x11 +25 (with 275/35/19 Falken452)
this came off from a g37
Thanks!
Thanks!
#291
19x9.5/11 +22 +25 wrapped with 225/35 255/35! Lowered on FUNCTION&FORM type 2 w/ no camber kits. Rolled and pulled! This is how it looks! Does it fit? Yes, but I'm going to be going lower so more pulling and a set of camber kits on its way!
![Name: 9535d4c4812a5a78bffdb9714aa75698.jpg
Size: 187.7 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/427518d1501329489-will-those-wheels-fit-an-is250-awd-part-uno-9535d4c4812a5a78bffdb9714aa75698.jpg)
#293
I have a 07 is250 awd lowered an inch in a half of h&r springs and looking to run bbs lm's 18x9.5 all around with a +22 offset do you guys think that's a good set up??
#297
I plan on getting these 18' replica bbs soon
8.0" F / 9.0" R Hub Bore: 73.1
38mm Front / 38mm Rear http://www.ebay.com/itm/330955266187...84.m1438.l2648 what tire setup would look the best & not harm my is250 2008 awd system ?
#298
Ok so what if I ran that same size as I said but with a +30 offset would that suite the car better?!
#299
https://www.clublexus.com/forums/is-...ml#post8150577
Honestly I have no idea what offset you'd have to run on a 9.5 wide wheel to get it to sit flush.
